Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Cam Options.
Old Dec 3, 2008 | 09:13 PM
Riceinator's Avatar
Riceinator
Default Cam Options.
Is it worth upgrading my cam while running the speed density, or should I just convert over to mass air?
Old Dec 6, 2008 | 05:58 PM
JPJP's Avatar
JPJP
Personally, and since you are in the speed density section, keep it S.D. I know there are cams out there that will work w/ speed density but the selection is limited.
I recommend you do other things that will not affect the computer. Good things to do are 1.7 rockers, supercharge, more open flowing exhaust...
Old Dec 6, 2008 | 07:24 PM
Riceinator's Avatar
Riceinator
ok, thanks for the input.
Old Dec 7, 2008 | 03:50 PM
Night Terror's Avatar
Night Terror
Crower 15511 cam
Comp xe270hr cam
both SD compatiable...
basically to be SD compatible the cam must make enough vacume. cams with high duration don't make enough vac and will cuz the SD to run like dog ****.
Old Dec 7, 2008 | 04:40 PM
Riceinator's Avatar
Riceinator
thanks man.
Old Dec 9, 2008 | 06:06 PM
stangbanger87's Avatar
stangbanger87
xe264hr is also another option for a cam for sd
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
ChampInSD
Oct 2, 2015 04:55 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
