Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
carbureted supercharger?
Old Jun 2, 2010 | 08:59 PM
82foxbody's Avatar
82foxbody
Default carbureted supercharger?
i just traded for my car a couple days ago. its an '82 GT fully built all motor with a new t5 and a 3.73 rear end. i cant seem to find a supercharger kit for it anywhere. any ideas? also, due to the 3.73's my speedo is all out of whack. this is my first non-ecu vehicle. so does anyone know where to find speedo gears for a 3.73 recallibration?
Old Jun 3, 2010 | 01:31 PM
67mustang302's Avatar
67mustang302
Speedo gears you can get from most shops, I think places like Summit have them as well.
And both Procharger and Vortech make carb'd blower kits, but you'll need a good blow through carb, plus a boost referenced fuel pressure regulator, plumbing, and a bigger fuel pump.
Old Jun 4, 2010 | 06:00 AM
ausi420's Avatar
ausi420
you have the same question that i do. i have an 85 5.0 i put 4:10 gears in the rear end, but i can't seem to find anything for carb mustangs.
Old Jun 10, 2010 | 09:20 PM
JPJP's Avatar
JPJP
http://www.paxtonauto.com/product.php?id=111
Check out the link..........
Old Jun 17, 2010 | 07:55 PM
82foxbody's Avatar
82foxbody
got some literature from procharger today. it has carbureted setups for '85-'93. any idea if these setups will work? i would have asked them but their customer service is closed right now and they dont have an email address listed.
Old Jun 18, 2010 | 02:40 AM
67mustang302
You could bolt an 85-93 kit on if you used an 85-93 timing cover and accessory setup. Call them when someone is there, they'll have the answers. They probably have a universal bracket and spacer kit that can be used for your setup as well.
Old Jul 7, 2010 | 12:33 AM
user 6927082424's Avatar
user 6927082424
Banned
Smile
In reference to the questions about Speedometer issues,
I drive an '83 mustang and I order a lot of my parts from http://www.50resto.com
they have several speedometers, parts, cables, gears, and gauge dress up stuff.
Here is a link to the speedo gears http://www.latemodelrestoration.com/...eed-Correction
Hope this helps, I ordered a 145mph speedo from this site for my '83 and its worked out great.
Old Jul 7, 2010 | 11:24 AM
82foxbody's Avatar
82foxbody
Thanks for the info guys. very helpful. i found this info on the link posted by jtr for anyone with aftermarket gear ratios. hope it helps someone
Ring & Pinion Speedo Gear Part Number
1983-89 Mustang Manual 5-Speed
3.08 18 Tooth LRS-17271H-K
3.27 19 Tooth LRS-17271A-K
3.55 20 Tooth LRS-17271B-K
3.73 21 Tooth LRS-17271C-K
4.10 23 Tooth LRS-17271D-K
1990-93 Mustang Manual 5-Speed
3.08 20 Tooth LRS-17271B-K
3.27 21 Tooth LRS-17271C-K
3.55 23 Tooth LRS-17271D-K
1984-89 Mustang Automatic AOD
3.27 19 Tooth LRS-17271E-K
3.55 20 Tooth LRS-17271F-K
3.73 21 Tooth LRS-17271G-K
4.10 23 Tooth LRS-17271J-K
1990-93 Mustang Automatic AOD
2.73 19 Tooth LRS-17271E-K
3.08 20 Tooth LRS-17271F-K
3.27 21 Tooth LRS-17271G-K
3.55 23 Tooth LRS-17271J-K
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
