Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Evaluate this idea..
Old Nov 8, 2010 | 02:54 AM
Molczn00's Avatar
Molczn00
Default Evaluate this idea..
First i have a 302 with a 650 cfm Edelbrock Carb
I think my motor is running rich because...
-There is a smell of gas.
-I get a white smoke from the pipes only when i sit at an idle.
-The smoke does not give me the appearance of coolant or oil really.
-The tailpipes have what seems like quite a bit of carbon build up.
-My plugs appeared to have a dark liquid carbon build up on them.
To fix this I need to...
-Get a vacuum gauge and hook it up to the carb.
-Turn down the tuning screws (sorry don't know the term.)
-Unscrew them until I get a higher vacuum and stop when the vacuum drops again.
Is this all sounding right? what is your guys opinions? I feel I could have a bad seal in the motor and oil could be getting in but its not constant. I also feel it could be the valve stem seals but once again it only smokes on the idle.
Thanks in advance guys.
Old Nov 16, 2010 | 10:24 AM
Nolan6121's Avatar
Nolan6121
I think it's an oil issue... Although if the carb is rich it will burn white smoke.... I notice on mine (I got a Edelbrock 600) when I floor it when it startes off cold, it blows white smoke. I smell gas on mine too, does it do it when it startes up? If so it's normal, 302's burn a little oil.
Old Nov 20, 2010 | 08:02 AM
holyshift's Avatar
holyshift
Put new plugs in,take it down the street,make a wide open throttle pass,and shut it off....pull plugs and take a pic and post.....That will better help us determine if its a carb problem,or maybe a water problem.
Young4myAge
Feb 17, 2007 12:46 AM
mustangmike50
Aug 17, 2006 10:06 PM
SonicStanGirl
Jul 31, 2006 05:26 PM
