Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Timing question
Old Dec 6, 2010 | 08:45 PM
306and351LX's Avatar
306and351LX
Default Timing question
I have a 1990 LX with a 302 block bored 0.30 over to a 306 with D00E 351 heads. I have an F303 cam, fully upgraded fuel delivery. I have timed the car before at 0 degrees before TDC. The car seems to idle fine when it is timed there. When I get in the throttle, the motor seems to bog down as if its not getting any fuel or too much air and not enough fuel. Now I am timed at 30 degrees before TDC. The motor has more of a flat line idle as if I had no cam at all and produces maximum hp and torque at 30 degress all the way to 8000 rpms. Should I try to find a middle point or advance my timing more than 30? Are their other variables that could be involved?
Old Dec 6, 2010 | 09:08 PM
a_penquin's Avatar
a_penquin
What are the specs on the cam, intake system work, still computer controlled ? I would keep tweaking the timing till you find the sweet spot.
Old Dec 9, 2010 | 09:20 PM
Venomantidote95's Avatar
Venomantidote95
Well if you want it to run correctly if it is efi still, put the base timing on 10-18* that means the timing spout out! then reinstall the spout and the ecm will take control and off u go!
if it is swapped to carb then u might wanna set it to about 36* and leave the spout out if it is running thru the ecm still, if fully after market ignition then just set to the desired setting and go on!
the fcam is a .512/.512 lift with a 226/226 duration i believe!
Old Dec 19, 2010 | 04:24 PM
toplessLx's Avatar
toplessLx
if its a flat idle your timing is to high. bring it down a little. see how that works. have u considering adjusting your carb?
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
