Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
85 gt Fuel problem
Old Apr 11, 2012 | 10:51 AM
ecstokely's Avatar
ecstokely
Default 85 gt Fuel problem
Recently to get the car to start I have had to crank it for about 30 seconds when its cold. After some inspection, I discovered the fuel filter right before the carb it totally drained. I believe there is no pressure regulator, so I assumed it would be my fuel pump is not holding any pressure. Just wanted to see what everyone thinks before I spend a 100 bucks on a new one. Thanks!
Old Apr 12, 2012 | 09:02 PM
oldfordisbetter's Avatar
oldfordisbetter
i seem to have the same problem on my 85 gt hatch also... whenever i try to crank it for the first time it just wont turn over. itll crank and crank but no start. then i stop n try again and it turns right over after some pumping of the gas. it gets embarrising after a wile... i was told i need to retard the timing... i need to do complete tune up oil change soon anyways. also its only a weekend/ nice day car....
Old Apr 18, 2012 | 01:24 PM
ecstokely's Avatar
ecstokely
I ended up doing a full tune up and checked my timing. All seemed well. I have a clear Fuel filter right before the carb and after a few hours of sitting it empty's. I cant find a leak anywhere and it now has a new fuel pump. I dont know what else to do at this point, since Im not much of a mechanic. It has gotten embarrassing though. Kind of a bummer, I just busted it out for the summer (wisconsin winters arent very good for it) and now I can hardly drive it
Old Apr 20, 2012 | 08:11 PM
oldfordisbetter
ho hard / long did it take to do fuel pump... im having someone look at the car tomorrow.. ill let ya know what he says/does to it..
Old Apr 21, 2012 | 10:20 AM
ecstokely's Avatar
ecstokely
It was super easy. Like 4 bolts and 25 minutes. It would have been quicker but the nut if my fuel line ( carb to pump) was stripped.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
