Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
what jets
Old Mar 11, 2013 | 10:56 PM
load1234's Avatar
load1234
Default what jets
So, got a 650 Holley mechanical secondary, sitting on a edelbrock rpm air gap with edelbrock 58cc heads. Before I put the heads on, I had 58/60 jets in the carb. Do yall think I should go bigger with the jets. It's a 1986 5.0 block
Old Mar 11, 2013 | 11:14 PM
tinman's Avatar
tinman
Are you near sea level? If so I would try it with the same jets that you had in it.
I would be real careful about using larger jets.
Old Mar 11, 2013 | 11:51 PM
load1234's Avatar
load1234
Yeah, I was thinking about going back to the factory ones that came with the carb. I just don't want to run super lean on the break in for my aluminum heads
Old Mar 14, 2013 | 11:58 PM
tinman's Avatar
tinman
Holley carbs are usually jetted for sea level at the factory..........
Nov 10, 2015 11:39 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
Sandmanbjj
Aug 21, 2015 12:38 PM
rwcstang
May 4, 2004 10:13 PM
TheGmKiller331
Feb 16, 2004 07:16 AM
