Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Computer not grounding the fuel pump...
Old Oct 5, 2023 | 03:22 PM
Tank Mech's Avatar
Tank Mech
Default Computer not grounding the fuel pump...
1986 LX with a 3.8/auto 89,000km's on it.
Car got back from the drag strip, parked it and it sat for a week or so. (exact same as normal) Jumped in today to get it ready and hit the key and the fuel pump didn't bzzzzzt and shut of like normal, it just sputtered a bit and silence. Rolled over and fired up and stalled with no fuel. Cycle the key and about every 5th time the pump would give a little bzt.
So, Pulled the relay from under the seat, still new but bench tested it anyway, works fine. Jumped between Yellow and red/black and pump runs.
Pulled the computer and tested the tan/grn tracer wire for continuity between the computer connector and the relay connector. It has continuity.
I got this computer from rockauto about 8 months ago and this is the first issue I've had. I haven't tested the other relay trigger wire, came in the house to cool off before something got destroyed from anger!
I'll test the second relay trigger wire and hopefully find a break in the circuit, but, anything else I could possibly look at?
(roll over switch is good or the pump wouldn't run when you jump the relay.)
Any idea's??
Old Dec 8, 2024 | 10:08 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
If it was mine, I would maybe just look at making the thing run however I can. Even if it takes just wiring in my own relay for the fuel pump.
Old Dec 9, 2024 | 08:29 AM
drhoward's Avatar
drhoward
Penis Mod Erator
Do the foxes have a ccrm? I know they can go bad occasionally in the later model cars and cause issues with the fuel pump....I can't remember if the older foxes had them or not
Old Dec 9, 2024 | 12:30 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
you mean like on the wistributor?
Old Dec 9, 2024 | 01:00 PM
drhoward's Avatar
drhoward
Penis Mod Erator
This thing:
It's just a bunch of relays but I've read it can cause issues with your fuel pump not kicking on - not sure if foxes have them or not though (I thought they did)
white91stang
Oct 10, 2010 09:29 PM
9165pt0
Oct 1, 2009 08:50 PM
fast_five_oh
Jan 21, 2009 08:57 PM
bjlo4life
Jun 21, 2008 08:34 PM
89mustangfive0
Jun 19, 2008 08:26 PM
