StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
BUMPSTOP
Old Jul 24, 2006 | 08:27 PM
GlockPants's Avatar
GlockPants
Default BUMPSTOP
Where does the bumpstop go that comes in Eibach sportline spring packages? Ive got a 96 V6.
Old Jul 24, 2006 | 08:51 PM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: BUMPSTOP
It goes above the differential, on the frame of your Mustang. It replaces the larger rubber bumpstop currently found on your car.
Carefully go underneath the car (with proper supports). You will then see the rubber bumpstop above the differential in the rear...
Sincerely,
Old Jul 24, 2006 | 11:29 PM
GlockPants's Avatar
GlockPants
Wow, that sounds so easy after Ive already put the springs and shocks in the rear end. Will it be ok to drive short distances without the bumpstop there for about a week when I can install the front? or could it damage components?
Old Jul 24, 2006 | 11:31 PM
STANGSUSPENSION
Former Sponsor
You only need the bumpstop if the rear end is bottoming out.
Alot of times, if your shocks are not worn, or you get new shocks... your car may never bottom out.
I would wait, see if the stock bumpstop is causing any issues... if so... then change it...
Old Jul 24, 2006 | 11:47 PM
GlockPants's Avatar
GlockPants
Thanks for the help. I really appreciate the customer service from your company. I guess its good seeing as how Ive bought over $700 worth of parts from you in the last month. Thanks again.
cedarmn
Aug 20, 2015 03:14 PM
RWHEELS
Jun 18, 2015 12:33 PM
Blair
Apr 23, 2010 07:31 PM
Blair
Mar 13, 2010 05:03 PM
The Yellow Pinto
Jul 30, 2008 01:00 PM
