Steeda Autosports Steeda Autosports is Ford's #1 aftermarket performance parts manufacturer. Steeda's parts are manufactured to ISO-9001-2000 standards and are thoroughly tested and proven on race tracks and on the street. Specializing in suspension and performance parts. Steeda also carries a variety of outside vendor products making Steeda your one stop shop for performance!
Curing Low Roll Center on S197 Mustangs With Steeda Ball Joints
Old 10-08-2015, 08:52 PM
tj@steeda's Avatar
Default Curing Low Roll Center on S197 Mustangs With Steeda Ball Joints
Hello All:
Great article written on the Steeda Ball Joints:
http://www.mustangandfords.com/how-t...a-ball-joints/
By using a taller ball joint and raising the spindle relative to the ball joint pivot point, the roll center is raised back into the correct range for optimum handling, resulting in reduced body roll, quicker steering response, and improved front tire grip. That’s straight from the one company that has had the foresight to have specific custom ball joints made to fix this issue with Mustangs: Steeda.
You can check them out here - http://www.steeda.com/steeda-x5-must...ints-555-8108/
Best Regards,
TJ
tj@steeda is offline
Gene K
10-21-2015 11:37 PM
09-24-2015 09:18 PM
stark777
09-21-2015 12:46 PM
09-16-2015 07:53 PM
09-10-2015 08:39 PM
Quick Reply: Curing Low Roll Center on S197 Mustangs With Steeda Ball Joints
