Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
launching?
Old Apr 6, 2006 | 12:15 AM
mackstang99's Avatar
mackstang99
Default launching?
ok agian this is gonna sound really dumb but how do you launch? i have an automatic so what do u do judt put it in drive and floor it or what? sry another dumb question still learnign
Old Apr 6, 2006 | 12:26 AM
JT76's Avatar
JT76
Default RE: launching?
turn traction control off (if equipped) and basically do a powerbreak and when u feel the wheels breaking loose let off the break and put it to the floor, thats what i do at least
Old Apr 6, 2006 | 12:34 AM
ByPopularDemand's Avatar
ByPopularDemand
Or powerbrake till the wheels are about to break loose then floor it.
Old Apr 6, 2006 | 12:55 AM
fordguy17's Avatar
fordguy17
if you rear tires can stick good here is what you do.
put your foot firmly on the brake, while the car is in neutral. rev it to 2000 while pressing on the brake pedal. you should feel it going further to the floor. (due to vacuum)
put it in drive and slowly give it gas until you feel the tires start to spin. back off the gas until they stop.
hammer the gas and release the brake at the same time.
this works alot better with an aftermarket converter since you can launch at much higher rpms.
Old Apr 6, 2006 | 01:24 AM
JT76's Avatar
JT76
I thought revving it and then putting it into drive is bad for the tranny?
Old Apr 6, 2006 | 01:34 AM
fordguy17's Avatar
fordguy17
ORIGINAL: stanggang1892
it is. you wait for the revs to come down before you put it back in drive. revving it is for the sole purpose of getting the brakes further to the floor.
Old Apr 6, 2006 | 01:35 AM
weasel1088's Avatar
weasel1088
he is saying only rev to get the brake booster to give better vacuum. then let off the gas, put it in drive then proceed with what he said.
Old Apr 6, 2006 | 01:41 AM
JT76's Avatar
JT76
oh ic ic i read it wrong thanks for the tip
Old Apr 6, 2006 | 02:27 AM
so1o2k3's Avatar
so1o2k3
wow didnt know all this complication was involved in launching an automatic
Old Apr 6, 2006 | 02:45 AM
92hatchLX's Avatar
92hatchLX
I don't see you having time to do this when you are staged and the other person is staged on a track, but it really does work. I suppose for the street it would work though. I tried revving it in neutral today while applying the brake and the brake pedal actually went to the floor quite a bit more, so yes it does work. Otherwise, preload it to what the converter will allow without moving the tires, and when the time is right mash the gas as you quickly let off the brake.
