Question for Si
Guest
Posts: n/a
ORIGINAL: ByPopularDemand
So whats the point of the swap to save like 80 pounds
But that 80 lbs, extra 10 hp and 12 ft lbs will go a lot further. If it was an EG coupe (EX), he just gained at the least 45 extra horses.
So wouldnt modding a GSR be more effective/ cheaper in the long run, than swapping it into a coupe of almost the same weight.
plus, HASPORT has engine mounts/wiring harnesses and stuff to make the swaps EASY. a baby could probably do it. they mostly bolt right in. with just a motor mount kit and a pre-made wiring harness. no biggie. i have friends doing complete swaps in one day...IF THAT LONG.
I like the GSR body too. I just thought the swaps were meant for the 1700lb hatches. BTW dont the GSR engines cost a bit too
you can get a full GSR swap(engine, tranny, ecu, axles, etc, etc) usually for like $2800-$3500 COMPLETE depending on what year you get. minus the motor mounts and a few odds n ends. and thats from HMotorsOnline...probably the MOST respected jdm honda/acura engine importer to the US. ive never heard anything bad about them.
civics/integras/accords/preludes.........damn near everything is swappable with a motor mount kit and a wiring harness. my friend has a '97 EX Civic coupe with an H22 dohc vtec engine, running an Accord 5-spd tranny(b/c of longer gear ratios over the H22 tranny). his car is FAST. itd wax my car any day of the week....from a roll anyway. from a light, now, id kill him
but thats why so many like Honda/Acura. easy to work on, parts are EVERYWHERE if you need them, and theyre reliable.
