Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Rolled a SS
Old May 2, 2006 | 08:58 PM
40thgtfl's Avatar
40thgtfl
Default RE: Rolled a SS
nice kill
Old May 2, 2006 | 10:41 PM
WLingle92lx's Avatar
WLingle92lx
Sleeper_Stang_89: What mods do you have?
WLingle92lx
Edit: double post
Old May 2, 2006 | 11:49 PM
Sleeper_Stang_89's Avatar
Sleeper_Stang_89
331 with full boltons H/C/I 373 gears.Only went from 45 to 80 had 3-3.5 cars so i shut down.
Old May 3, 2006 | 06:45 PM
WLingle92lx
How much hp you making?
Old May 3, 2006 | 08:51 PM
Sleeper_Stang_89
Just over 300. Im still working on susp then planning on going back on the dyno to fine tune it alittle more.
Old May 3, 2006 | 08:55 PM
98LS1's Avatar
98LS1
Must be one LOW compression 331.
Old May 4, 2006 | 12:45 AM
96SilverLT1's Avatar
96SilverLT1
anyone else find this a bit odd?
Old May 4, 2006 | 09:22 AM
Sleeper_Stang_89
96 why would you find this odd rsw ran 12.8 with 232 hp. I know that some just don't understand that 300 hp and 340 ftlb could beat a SS.
98 comp is 9:1
Old May 4, 2006 | 11:28 AM
96SilverLT1
that's exactly my point. The only way your going to run 12.8 on 232 HP is if:
Your 60 foot is a negative number.
or
Your car weighs less then you do.
Possibly a combination of both. Otherwise, it's not going to happen. But the fact that you beat this car "from a roll" means that 60 foot is totaly off the table for this. At this point, it's a HP and weight race. A stock SS will put down more then 300 HP to the wheels. So he has you on power. The only way you could "pull him" given that he has more power, is if you weigh a lot (and I mean a lot) less then him.
Then the fact comes in that you don't list your mods. you give very vague details as to your car that cant really be substantiated at all. Then you really drop the ball and claim that you never went WOT against him and still pulled on him. Not only is this not possible, it's mildly retarded.
So here is the situation. You never rolled an SS. You did however, Roll a joint, and then proceed to "race" a V6 camaro to which you thought was an SS because you were then high.
