Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
351 Windsor?
Old Jun 17, 2006 | 02:54 AM
MaddMaxx's Avatar
MaddMaxx
Default 351 Windsor?
I am thinking about putting a 351 Windsor in my 1990 Coupe LX. I have a 1986 bronco with a carborated Windsor sitting in my yard, and figured what the hell. What parts do you guys think I should use. You know heads, cam, pistons etc... I am in college so I need to know the best parts at the best price. I am hopeing to get the car into the high 11's. I would also like to get 12-14 mpg as well, do you think it is possible. I was planning on running a 75-125 hp shot of nitrous with a C-6 automatic transmission with overdrive, a shift kit, a trans. brake, and a B&M stall converter. Also does anyone know what motor mounts I need to get, because the cylinder angle of the Windsor is different from the 5.0 Liter?
Old Jun 17, 2006 | 03:00 AM
Clif Brohn's Avatar
Clif Brohn
Default RE: 351 Windsor?
All you REALLY need are a bigger hood and a different oil pan, and it will bolt right in. Only big differences between the two are the Windosr is a bit wider, different crank and stroke and a taller deck to get the displacement. Way better than a 5.0, and I am actually building a 351W to put in a fox right now. As for performance parts, this is both in the wrong section and there are so many possibilities that it would useless to try and set a direction for the project.
Old Jun 17, 2006 | 03:11 AM
MaddMaxx's Avatar
MaddMaxx
Thanks for the info, and sorry this isn't the right forum. I am still wondering if I could get the car into the high 11's and still make my goal of 12-14 mpg.
Old Jun 17, 2006 | 03:50 AM
Clif Brohn's Avatar
Clif Brohn
ORIGINAL: MaddMaxx
With the right fuel injection setup and tune, no rpoblem! Hey, gimme a PM with any Qs on this. I'll give ya a good website to check out, and since this might be my next project, I've spent the last month or so researching the 351W's aftermarket and power yields from certain setups. Ask anything you want.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
89blueslug
Aug 10, 2015 07:20 AM
