Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Killed a Cobolt SS/SC
Old Jun 24, 2006 | 02:28 PM
STANMAN's Avatar
STANMAN
Default RE: Killed a Cobolt SS/SC
Thanks Cody, I will let him know. It sounded to me by his description that the clutch was slipping, but I thought it was just him, as like I said he knew NOTHING about his car.
And yeah, I was in the Stang.
Old Jun 24, 2006 | 02:29 PM
NickTsGTP's Avatar
NickTsGTP
Cody you should go to INTENSE-Racing.com, they've got all sorts of performance stuff for the cobalts. I was at Intense Drag Days, and they had several Cobalts running low 13's out there.
Old Jun 24, 2006 | 04:03 PM
FoxRod's Avatar
FoxRod
ORIGINAL: 01SilverGT
ORIGINAL: V6MustangKnight
wow, sounds like a fun run!!! hey, quick question....if i get 3.73s for my car, will that give me any rwtq? still a newb here so i dont know what exactly the gears will do except launch me faster...
Gears dont add any power of any kind. It just helps with acceleration.
Why are you going with 3.73's? Get some 4.10's, those will really help out your v6.
You correct and not correct at the same time. True gears do help with acceleration (the taller you go) BUT they do add power, in a sense. Do that actually "add" power no, BUT multply your pre-existing torque. Hence the code name "torque multiplication" or "torque multiplier" So in a sense it does "add" power.
If you go to a dyno with stock gearing (say 3.08) then throw in some 3.73's or 4.10's your RWTQ will but much higher.
Old Jun 24, 2006 | 04:24 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: FoxRod
You should not see any TQ increase on a dyno from your gears.
At least I did not see any difference. Nor has comparing several different peoples dynos with different gearsets but the same basic power mods shown this.
Acutally, the higher the gear ratio, the slightly low you will dyno. I have seen people loose a few RWHP after a gear swap.
Old Jun 24, 2006 | 04:43 PM
Driver72's Avatar
Driver72
He probably meant that after the dyno it showed the stock Cobalt SS was closer to 235 hp at the crank.
And I can believe that. I find it hard to believe that adding the supercharger on that car only added like 40-45 hp too.
And with the numbers (trap speeds) the Cobalt SS is producing, it's surely putting out more than the 205 hp Chevy
advertises.
235-240 crank HP seems more correct.
Old Jun 24, 2006 | 04:49 PM
FoxRod's Avatar
FoxRod
ORIGINAL: 2000GT4.6
ORIGINAL: FoxRod
You've seen peoples Torque go down after a gear swap? Are you sure they didn't go down in gearing? And you should see more torque at a lower RPM. That's the point of them. Hence the increased acceleration. They do kill top end though. That's why you might have seen the HP go down. But all horsepower is, is a number created from taking torque, gearing, and a few other things multiplied and divided together. Not sure of the exact equation but something like that.
Old Jun 25, 2006 | 07:06 AM
White2000GT's Avatar
White2000GT
Good kill Stan!
Now, the way I understand how gears work is like what was mentioned already. They simply multiply the existing torque that the engine produces. Basically, if you swap your stock gears out for say 3.73's then the gears simply make it easier for the torque that your engine produces to get the car rolling... gets it off the line quicker and gets you into the higher revs quicker. I know there are some more complex mathematical equations that are actually involved though.
Old Jun 25, 2006 | 07:09 AM
redass02gt's Avatar
redass02gt
EXTREME Moderation
ORIGINAL: CodySS
no ****in' way this is possible, **** you all!
edit: I suck ***
Old Jun 25, 2006 | 07:22 AM
headturningV8's Avatar
headturningV8
cody , u should go to straponapiar.com/coboltsaregay/slow/imdrunk/redlinesmurkthatslowbolt
Old Jun 25, 2006 | 07:26 AM
redass02gt's Avatar
redass02gt
EXTREME Moderation
I hope you know that wasn't really cody. [sm=bustedsign.gif][sm=icon_rofl.gif]
