Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Track tonight - results
Old Jul 26, 2006 | 03:09 PM
Dan04COBRA's Avatar
Dan04COBRA
Default Track tonight - results
I'm off at 5. First runs are at 6 or a little after. It's a 10 minute ride, so I'll be staying out of boost and letting the car cool for atleast 30 mins before my first run to rip a wonderful....... 13 second ET!
Hopefully I can get the car to hook decently and I'll be able to run sub 12.99 without powershifting while I get back in the groove of running down the track.
DA is going to be around 3784 tonight according to the weather & my calculations. I'll double check the DA after I'm home and post my corrected results.
Any bets on what you think I'll run?
Old Jul 26, 2006 | 03:10 PM
LittleMT's Avatar
LittleMT
Default RE: Track tonight
Good luck to you, ice your blower and intake down some after you get there and inbetween pases, lower that tire pressure and get that 12!
Old Jul 26, 2006 | 03:13 PM
Dan04COBRA's Avatar
Dan04COBRA
I have street tires. Any lowering of pressure I've done has made the situation worse.
I prefer no ice because it pisses me off when people ice their cars in the lanes and I'm dragging my front tires through it all the way up to the beams.
Old Jul 26, 2006 | 03:14 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
13.3's dan, cause you'll go baked, and barely survive
Old Jul 26, 2006 | 03:16 PM
Dan04COBRA's Avatar
Dan04COBRA
No no no, sober...freak!
LittleMT's Avatar
LittleMT
We ice down our cars in the pit area and do wipe them dry prior to pushing them out to the staging lanes, as I agree with you, no need to wet the lanes for others...
I usually field 3-4 cars when I go out, some with slicks others with street tires. In my case, lower tire pressure on street tires and a quick dry burnout to remove debris from the threads have netted us
the best results..
Anyways, good luck on your quest for the 12!
Old Jul 26, 2006 | 03:18 PM
Dan04COBRA's Avatar
Dan04COBRA
I keep the pressures at what the tire recommends and simply give them a quick cleaning.
There will be some bracket racing, so I'm figuring track prep will be decent.
Old Jul 26, 2006 | 03:23 PM
LittleMT's Avatar
LittleMT
ORIGINAL: Dan04COBRA
excellent, track prep will certianly aide you in that lower 60ft time..
I also run at a high altitude, and it makes it rather tough to run solid times...
Old Jul 26, 2006 | 03:26 PM
eindow's Avatar
eindow
13.089.... on your second to last run...
Old Jul 26, 2006 | 03:39 PM
blackbetty01's Avatar
blackbetty01
Tonight will be my first night at the track if the rain stays up north. If my buddy lets me use his MT's as promised I think I should be able to break 12's tonight.
