smoked by s2k sc
#23
RE: smoked by s2k sc
ORIGINAL: deezelnut
last i checked the new stangs were one of the fastest cars under 30k. the 05 GTs are consistently in the high-13s with good drivers. last i checked that was pretty quick for a 3500 lb stock car.
#24
ORIGINAL: Grn N Gry 5OH
u have a turbo'd 4-dr EG and a S2k or youre building it for someone ??
ORIGINAL: Civic4doorsleeper
wrong... very wrong. Also theres plenty boosted s2000 with 500+whp with just a headgasket.. Im building one right now actually
ORIGINAL: David_K
s2k are slow even with a blower they can only make 240 rwhp due to high compression pistons
#25
ORIGINAL: 2000Si
You get funnier and funnier every day.
ORIGINAL: David_K
#26
ORIGINAL: David_K
i race with a guy with a white one that has the vortedch blower and hes making 240 exactly and swear up and down that a smaller pulley would blow his engine. there was one guy i raced with that had a 2004 comptech supercharge NSX and he did a pulley swap and blew the motor on 15 psi
ORIGINAL: 2000Si
ORIGINAL: David_K
#27
Guest
Posts: n/a
ORIGINAL: David_K
ORIGINAL: 2000Si
ORIGINAL: David_K
who makes exactly 240 to the wheels on a dyno? What? No. I've seen them put down a hell of a lot more than that on 8 psi.
I watched a video of a 99 Cobra put a rod through it's block after running a turbo on 8 psi and not tuning his car.
#28
ORIGINAL: 2000Si
That's because he put 15 PSI into a 10+:1 CR engine without building it first...
ORIGINAL: David_K
ORIGINAL: 2000Si
ORIGINAL: David_K
#29
ORIGINAL: Black2007
Todays Mustang is HEAVY.....NOSE heavy....weight distribution, weight transfer, power to weight ratio, engine rpm, torque, aero, gear ratios, all work against a Mustang in a street fight with a fwd, turbo'd or s/c light weight 4 banger with a good driver. Don't get me wrong, I love my Mustang, but its not a drag car or even a fast car, what it is ...is a great looking GT with and excellent ride..If you bought it thinking you can mod it up to compete with whats on the street today, be prepared to invest heavily in suspension upgrades, a better transmission, more displacement, room for more tire....and shift all the weight possible toward the rear of the car. If it doesn't hook up, nothing else matters much. You can have all RWH in the world and it won't matter.
#30
howdy all...
wow.... i haven't been on this site for awhile..anyways i have a 04 s2k with a Vortech blower running stock boost...Just wanted to make a post in order to clear some things up.Haven't been to the track but i should be good for high 12's in the 1/4 mile.And i'm putting down around 300whp with just the blower and a test pipe.My car is about 2800lbs.A well drivin stock s2k should be good for high 13's in the 1/4 mile.on s2ki.com we have had some get 13.7...but on average it's about a 14.1 second car.I'm thinking about upgrading the boost but like most of you know it gets pretty expensive.just cause it's a 4 banger shouldn't underestimate s2k's we have guys putting down 500whp+.to the OP don't sweat it we all get beat sooner or later..always gonna be a faster car around.
Peace
David
Peace
David
