Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
It never ends.
Old Nov 7, 2006 | 10:20 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default It never ends.
Old Nov 7, 2006 | 10:38 PM
TommyV8's Avatar
TommyV8
Default RE: It never ends.
Aaaaaaawwwwww shiiiiiiiiiiiiiiit![sm=badbadbad.gif]
Old Nov 7, 2006 | 10:51 PM
mustangman02232's Avatar
mustangman02232
and thats going on????????????????????????????
Old Nov 7, 2006 | 10:58 PM
JD1969's Avatar
JD1969
The SS. It's called the 6.0L truck manifold turbo. Basicly a cheap way to turbo my car, now I just need to find an intercooler and fab the piping and few other little things. The Turbo is a Precision PT51, good for about 550 hp, but this is just a start, I needed a turbo for mock-up and a buddy had this one laying around. After I get it going with the PT51 I will be swaping it for a bigger one.
Old Nov 7, 2006 | 11:03 PM
mustangman02232
how much psi? what compression ratio?
Old Nov 7, 2006 | 11:17 PM
JD1969's Avatar
JD1969
ORIGINAL: mustangman02232
Stock compression for now (10.25) I know it's kinda high but with the cam I am using a lot of compression will bleed off. I am only going to run 8 psi or less, but that should be good for at least another 100 hp or so. I figure I can get into the 10's with it.
Old Nov 7, 2006 | 11:22 PM
TommyV8's Avatar
TommyV8
I keep seeing the compression listed as 10.1. Do different LS1s have different CRs or something?
Old Nov 7, 2006 | 11:31 PM
Dan04COBRA's Avatar
Dan04COBRA
Jeezass.
Sell it to me when you are done?
JD1969's Avatar
JD1969
ORIGINAL: TommyV8
I thought it was 10.2, either way it's real close. I am pretty sure that all LS1's had the same.
Old Nov 7, 2006 | 11:37 PM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
i thought this was suppose to be secret ?? [&:] ...thanks for making me feel not special [&o]
