Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
how do you get the best acceleration
Old Nov 10, 2006 | 02:37 AM
stanger88's Avatar
stanger88
I ♥ Acer
Default RE: how do you get the best acceleration
ORIGINAL: HaV
dont just stomp the gas or you wont go anyways. THe best way is to hold the break and the gas together, kinda light on the brakes though.. hold it just to that point where you can feel the tires moving a bit.... when the light goes green dump the brake, then get on the gas more. It will roll you into it a bit so you dont spin as much.
Or get stickier tires and a stall.. same effect just a higher launch.
Auto GT's really dont have THAT much power. My friend could floor his 03 GT from a stand still and dead hook. he was stock.
Old Nov 10, 2006 | 03:26 AM
radaman's Avatar
radaman
ORIGINAL: stanger88
ORIGINAL: HaV
Its not the power as much as the stock converter(1800 stall). Autos just need to launch higher and will get way better times. If u race a stock 99-04 gt (DR's)manual vs auto (auto with a stock 3K stall) the auto will be even every time or even win. Thats a fact. The converter holds autos back.
Old Nov 11, 2006 | 05:11 PM
grrroundhog's Avatar
grrroundhog
I'm new to the lingo. What does 3200 stall mean? Lowering tire pressure is a good idea, btw. I didn't think of that.
Old Nov 11, 2006 | 08:02 PM
fiad06's Avatar
fiad06
ORIGINAL: stanger88
ORIGINAL: HaV
the auto tranny is almost near the same power as the 5spd..it doesnt spin much because it is starting off in a low rpm...its like if u punched a 5spd without reving it,, you would get the same results..
Old Nov 11, 2006 | 11:34 PM
MrMiracle's Avatar
MrMiracle
ORIGINAL: grrroundhog
A stall converter is a device that transfers the motion of the engine to the automatic transmission. The higher the difference between the speed of the engine and the speed of the auto, the more torque is multiplied. This is why an auto can get in motion from a dead stop even at idle.
However, stall converters are rated based on the point where the engine and the trans lock up, where they go at the same speed. Stock is 1800. An 1800 rpm difference is pretty good for normal driving. However, it also means you can't accelerate from a dead stop any higher than 1800 rpm. Swapping the converter for a 3200 means you can rev the engine up to 3200 at launch. That larger difference means more force is transferred from stop, better launch.
Old Nov 12, 2006 | 12:03 AM
radaman's Avatar
radaman
ORIGINAL: fiad06
ORIGINAL: stanger88
ORIGINAL: HaV
Exactly. Thats the main reason auto's normally run .2-.4 slower in the 1/4 than manuals. If they both launched at the same 3k+ rpm, shifts at the same rpm, it would be an even race or the auto would win as the shifts are dead on.
Old Nov 12, 2006 | 10:30 PM
grrroundhog
Default thanks for all the info
good to know
Old Nov 12, 2006 | 11:39 PM
JBradley500's Avatar
JBradley500
ORIGINAL: SSteele
I drive a Camaro
There's a difference between bogging and traction....
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
69Volunteer
Sep 30, 2015 10:39 AM
Offendant
Sep 23, 2015 07:21 PM
Sep 8, 2015 11:50 AM
zanemoseley
Sep 6, 2015 12:58 PM
