Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
how do you get the best acceleration
Old Nov 9, 2006 | 01:21 AM
grrroundhog's Avatar
grrroundhog
Default how do you get the best acceleration
I just bought a 2002 GT Convertible, 4-speed auto. Just curious how to get the fastest acceleration from a standing stop. I was told to deactivate overdrive, leave traction control ON, and just stomp the gas.
Old Nov 9, 2006 | 01:51 AM
HaV's Avatar
HaV
Default RE: how do you get the best acceleration
dont just stomp the gas or you wont go anyways. THe best way is to hold the break and the gas together, kinda light on the brakes though.. hold it just to that point where you can feel the tires moving a bit.... when the light goes green dump the brake, then get on the gas more. It will roll you into it a bit so you dont spin as much.
Or get stickier tires and a stall.. same effect just a higher launch.
Old Nov 9, 2006 | 02:11 AM
JT76's Avatar
JT76
traction control off, i usually leave the O/D alone too, all turning off O/D does is keep you from going into overdrive, which dont happen at WOT anyhow. If you leave Traction Control on, your engine will bog
Old Nov 9, 2006 | 01:54 PM
radaman's Avatar
radaman
ORIGINAL: grrroundhog
Get a 3200 stall, 4:10's (wish I had 4:30's now) and some drag radials and your car will yield some 1.8 60'. That will put you in the 13.5 range in the 1/4.
Old Nov 9, 2006 | 10:08 PM
yellowgtstang18's Avatar
yellowgtstang18
Hit the nitrous
RE: how do you get the best acceleration[/b]
Old Nov 9, 2006 | 10:16 PM
fiad06's Avatar
fiad06
Have mr rogers tow you
Old Nov 9, 2006 | 11:12 PM
SSteele's Avatar
SSteele
I drive a Camaro
Old Nov 9, 2006 | 11:21 PM
eindow's Avatar
eindow
Hit the pedal on the right[8D].... That works for me[&:]...
Old Nov 9, 2006 | 11:22 PM
MrRogers's Avatar
MrRogers
ORIGINAL: fiad06
LOL
Old Nov 10, 2006 | 12:41 AM
SVTBill's Avatar
SVTBill
drop your tire pressure down, turn trac off, preload to about 1300 then let er rip
