Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
First Time At Track
Old Nov 18, 2006 | 03:13 AM
  #21
Frostbitten's Avatar
Frostbitten
Default RE: First Time At Track
I ran about the same my first time at the track. Then I got it down to 9.1 with light bolt ons.
Old Nov 18, 2006 | 03:51 AM
  #22
01yellowgt's Avatar
01yellowgt
ORIGINAL: boss281
from my experience elevation makes a HUGE difference in performance. i used to read bout people getting mid 13s with their bolt on GTs only to find out that at 5000 FT the best that i could run about 95mph in the 1/4 and my best so far is 14.65 [:@]
edit: i would love to have an idea of what my could run at sea level where can i find a calculator that does that??
I use wunderground.com to pull up the weather statistics. and you can pull up old days so works good. others will pull up weather data for only the past day.
for the calculator I use Modular Depots calculator for caclulating ET at sea level
The run was at 7:30pm on May 6th of this year.
Based on:
Temp: 74.45°
Humidity: 52.5%
Track Altitude: 1850 feet
Pressure: 29.835 in.
Density Altitude = 3568 feet
ET MPH
Uncorrected 13.633 @ 98.67
Corrected 13.04 @ 102.94
Old Nov 18, 2006 | 04:18 AM
  #23
Quick Shot xMLx's Avatar
Quick Shot xMLx
Well my corrected time was 0.006th lower and my MPH was 0.09 higher so thanks to your calculator I feel slightly less bad[&:] The track was poorly prepped since there were only bout 10 cars out that night although I won't use that as an excuse. Next season I'll be ready for them....cheap 15" rims and some DRs
Old Nov 18, 2006 | 04:31 AM
  #24
01yellowgt's Avatar
01yellowgt
thats about the only way to get rdy. and do your best to make a pass after someone with slicks.
Old Nov 18, 2006 | 11:19 AM
  #25
boss281's Avatar
boss281
so my corrected time is 13.19 @105 does that sound right?? i think is too low/ fast for a bold on GT what do u guys think
btw 01yellowgt thanks for the calculator
Old Nov 18, 2006 | 11:37 AM
  #26
OneFine89Mustang's Avatar
OneFine89Mustang
not bad for your first time
Old Nov 18, 2006 | 12:17 PM
  #27
01yellowgt's Avatar
01yellowgt
ORIGINAL: boss281
a bolt on GT can get into the 12's if you got the suspension mods, and slicks. Because 13.19@105 there would still be more left in it et wise going by the mph. I wouldnt use the calc that would be exactly your time, but an estimate.
no problem
Old Nov 19, 2006 | 02:45 AM
  #28
ZW99GT's Avatar
ZW99GT
ORIGINAL: boss281
That ET is a little low. What are your mods. What was your 60ft?
carid
Jul 8, 2016 09:55 AM
StalkerGT
Sep 25, 2015 02:41 PM
RWHEELS
Sep 5, 2015 03:42 PM
whatsup62
Sep 3, 2015 01:38 PM
Sep 1, 2015 08:16 PM
