almost hit elevens
no im still at that same same h.p. but i was on m/t dam the things hook. what, you thought i was on street tires, and tommy v8 is totally right on the moey, n/a i was at 300 hp to the groung, and on street tires i ran 13.1 at 108
Was this with the Ninja?
That's a fast Saleen you got there, man. Also, 2nd gear is usually right behind first and works best if you wait for the clutch to engage.
You should have no trouble getting into the 11s, possibly even mid-11s.
ORIGINAL: C6 VETTE
Are you still putting down 410rwhp? Not saying you did'nt, but it's almost impossible to get a 3600lbs car to run a 12.1 with 410rwhp and missing second gear on top of that. Something does'nt sound right unless your sig is outdated and you are putting more ponies to the ground.
ORIGINAL: blackhorse05
well my first and only run i missed second, not bad but i did and stilled pulled out a 12.1, then someone blew the motor and sprayed the whole track with oil, so the night was done, but im almost thier, when i get thier ill be done
Sep 30, 2015 12:39 PM
