Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Gears?
Old Feb 13, 2007 | 01:12 AM
envygreenformy's Avatar
envygreenformy
Default Gears?
I have a 93 Firebird Formula A4 and was wondering about gears, like what do I have, what could I get, and what would be the drawbacks to installing a more aggressive gear. Also, I have bigger tires in the rear than the front, would it be beneficial to go with smaller diameter tires?
[align=left] [/align]
Old Feb 13, 2007 | 01:18 AM
snakeman4life's Avatar
snakeman4life
Default RE: Gears?
[sm=icon_stickpoke.gif]Isn't this the wrong forum???? J/K,IMO gears help any car,but the F Body guys can help you out more than me about what ratio would be best.
Old Feb 13, 2007 | 01:23 AM
Quick Shot xMLx's Avatar
Quick Shot xMLx
Default RE: Gears?
You "should" have either 3.23s or 2.77s or something like that. Gears definitely help of Mustangs and I'm sure it's the same for F-bodies. A lot of auto stangs go with 4.10s so you'll probably go with something like that.
Old Feb 13, 2007 | 01:34 AM
envygreenformy
Default RE: Gears?
Thanks guys, would changing my gear ratio kill my gas mileage?
Old Feb 13, 2007 | 01:37 AM
Quick Shot xMLx
Default RE: Gears?
ORIGINAL: envygreenformy
Depending on your driving habits they will lower it but they won't kill it. 1-2 mpg at most isn't a big deal
Old Feb 13, 2007 | 01:40 AM
snakeman4life
Default RE: Gears?
My gas mileage isn't much different around town,but it is noticeably worse on the highway.
Old Feb 13, 2007 | 11:40 AM
TommyV8's Avatar
TommyV8
Default RE: Gears?
You have either 2.73 gears like mine or the optional 3.23s. If you're turning 2000 rpm at 80 mph then you have 2.73s; higher rpm means 3.23 gears. I think the code on the door for 2.73s is GU2, I forget the code for 3.23s.
Old Feb 13, 2007 | 01:48 PM
envygreenformy
Default RE: Gears?
Thanks Tommy, I was spinning about 1800 rpms going 65-70, so...I assume I have the 3.23s. I think I'm just going to leave them alone, because I get great satisfaction when I get 29 mpg (well, the owner before me, but as soon as winter ends, its a road trip to figure out my mpg).
Old Feb 13, 2007 | 02:58 PM
mustangman02232's Avatar
mustangman02232
Default RE: Gears?
actually sounds like 2.73s, 3.42s are a nice upgrade for DD, i went with 3.73s behind my 700R4/4L60 (pretty much same thing) and well, sig explains it[8D]but thats because i dont get the ***** to the wall feeling that 4.10s would give or let me use the low end torque that 3.42s would of given me, well have to see when i get the cammed 350 in there in april
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
