round two vs camaro, race suggestions?
How do you know it's a 350, they are 100% identical externally as a 305 block.
It's a 305 with mods it can't handle. If he's lucky, it's a 350 with LB9 or LO3 heads and he's a complete moron. You told us he dyno'd 348FWHP in another thread.
The kid is just blowing smoke up your hiney my friend.
the maro should take you, andye im also guessing its a 305 no way you get him by those many cra lengths with 350 under the hood either he cant drive to save his life or hes full of it. nice run anyway
My '02 Camaro went 13.52 @ 104 stock. That is an automatic with 2.73 gears. My g/f's auto with 2.73's went 13.36 stock (factory freak I think). What tranny does the Camaro have? If he has an auto with 3.23 gears he should be a little quicker. If it's a 6-speed with 3.42 gears it may be capable of 12.9 with good conditions and excellent driving. Hope this helps.
No way you'll take an LS1. He'll walk you like a dog. Like everybody else already said, there's no way you put 10 car lengths on a 350 hp Camaro in a stock 5.0, so he's a lying sack of crap, you're a lying sack of crap, or he drives like a sack of crap. Either way you look at it, it's crap. lol.
ORIGINAL: USAMuscle
it couild be a 305 i suppose just the guy he bought the engine off told him its a 350 and it has 350 valve covers, how do u check? can u run numbers or something?
well if it is a older style 350 the oil dipstick will be on the driver side,and the 305 will be on the passenger side,and what i mean by older style is the valve covers will have four perimeter bolts instead of the center bolt valve covers
That doesn't count for 3rdgen 305/350's. Dipstick is on the same side, both motors look 100% identical. The only way to check it is to run the numbers on the block. Don't use the heads because many people swap out L03/LB9 heads for L98 heads.
I guarentee it's a stock 305. Stangpower makes a good point about the valve covers, but old 305's came the same way too.
