Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Why Can't I Launch?
Old Apr 21, 2007 | 02:12 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default RE: Why Can't I Launch?
I'll also be the first to admit, I have not practiced actually launching on the MT's on the street either in the entire 14K or so miles I've had them.
The other day mentioned in teh story is the first time I've launched hard next to another car doing so that wasn't occuring at the track. I've babied the tires to let them last *while at the same time probably not using them for what they were meant obviously* so I don't have alot of experiance in knowing how good I'm really doing.
Old Apr 21, 2007 | 02:24 PM
sipynsyrup's Avatar
sipynsyrup
Yeah those 60' times you listed are street tire range. A lot of people pull 1.9's on street tires.
You will never learn unless you practice
Old Apr 21, 2007 | 06:14 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: 72MachOne99GT
I don't know guys, suspension really is not my thing.
It's like investing money that you only see results from when you are at the track, and since I'm never at the track *once to twice a year* I just don't see the point of it.
But at the same time, I see people time slips with 1.9 and even some occasional 1.8 60' times on Nittos and BFG's and I'm pretty sure we can all agree that the tires sitting on the *** of my car are stickier/better than nittos and BFG's as well.
I don't know. I pulled a 2.05 60' once, and most recently at the track a 2.149 *which is stock tire range*
Hopefully up at Milan MI for our MustangForums meet I can impress everyone with a 1.9-high 1.8 range 60' time and rocket into the mid 13's in the 13.4-13.5 range.[>:]
Suspension will help out on the street as well as the track. The idea is to improve suspension geometry and reduce deflection.
Old Apr 22, 2007 | 01:47 PM
72MachOne99GT
I'm sure I can figure out what you mean by suspension geometry, and I've heard of deflection, but have no idea how it applies in automotive racing. *though I'm sure it has something to do with weight shift and the spot in which the weight is applied*
Old Apr 22, 2007 | 10:59 PM
JD1969's Avatar
JD1969
Research "instant center" it expalin some things. BTW I just got 275/50/15 M/T dr's and pulled 4 1.5x 60 foots today, and I got the front wheels about 3-5 inchs in the air, so it's definatly not the tire
Old Apr 23, 2007 | 03:56 PM
Chrome99's Avatar
Chrome99
I have the same exact tires and with mine i air them down to about 17 psi and slip theclutch at around 4000 on the street, i've had them nearlydead hook in a few instances but ususally have a tiny bit of spin and sometimes bog...But thats with stock gears...
Air them down and go out and practice!
Old Apr 23, 2007 | 04:11 PM
hotrod7687's Avatar
hotrod7687
ORIGINAL: JD1969
DAMN [sm=insomnia.gif] ...........Show off
There aint no way that was on the stock rear
Old Apr 23, 2007 | 04:33 PM
Sumguy30's Avatar
Sumguy30
ORIGINAL: 2000GT4.6
Gonna send ya a PM, but trust me the suspension is worth it. Its fairly cheap and it makes a big difference.
How cheap is fairly cheap? I havnt had my car very long and its bone stock too with the exception of the Shaker...not that it gives much gain.
Old Apr 23, 2007 | 05:58 PM
JD1969's Avatar
JD1969
ORIGINAL: hotrod7687
ORIGINAL: JD1969
As a matter of fact it was on the stock 10 boltwith 3.42 gears even.
Old Apr 23, 2007 | 06:34 PM
czwalga00gt's Avatar
czwalga00gt
ORIGINAL: JD1969
[sm=owned.gif]
