Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Why Can't I Launch?
Old Apr 23, 2007 | 07:31 PM
  #21
ZW99GT's Avatar
ZW99GT
Default RE: Why Can't I Launch?
I think you are being too easy with your tires. 14k miles? Have you EVER done a good smokey burnout even once?
I bet if you would use those tires the way the are supposed to be used, You would be in the 1.7's. Hell, Even I did it with the Stock IRS. Same tires
Old Apr 23, 2007 | 08:17 PM
  #22
Zanador's Avatar
Zanador
Holy god, you pulled a 1.5 on a 10 bolt?!?!?!? Your 10 bolt must be blessed by god or something... that is NUTS, you shouldve left metal bits all over the track!
Old Apr 23, 2007 | 08:29 PM
  #23
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Zanador
Auto's are ton easier on the rear end. I load the chassis so the launch does not shock the ring and pinion so hard and I do have control arms so wheel hop is not an issue. But I do know that it might go BOOM at anytime[&:]. I have seen a stock 10 go 1.48's and it is still going strong, but that is far from the norm.
Old Apr 23, 2007 | 11:38 PM
  #24
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
ORIGINAL: ZW99GT
I suppose this is a possibility. I don't know. Since I got them I have babied them. But that does'nt explain why I can't launch on them.
I'll make myself proud on the 17th though. I HAVE to. Or else.
*by the way, thats the Milan meet and I will go 13.5 on a 1.9 or better 60'*
ctgreddy
Oct 14, 2015 09:05 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
vintageaion
Sep 8, 2015 10:45 AM
