ME vs. WRX
That car will be comparable, if not slightly faster, than a stock STi.
I just talked to him. For now he will be running 14 psi with a turbo-back exhaust, ecu flash, and an air filter. Where will this put him? Mid 13's? I'm sure he will beat me if we run, but it will be fun. IF we run it will be from a roll, and I figure the lower the better for me. What do you guys think?
Well he must be leaving it there then. Before long he will bump it up to 17 psi, after he gets his other parts on. So a down pipe, cat-back, ecu, air filter, 17 psi on his '07 WRX wagon around where? Am I right in saying the lower we go from a roll, the better for me? I don't want his AWD to be of use, and I also don't want his turbo fully spooled.
Be a man and go from a dig. That's how all races should be won
You'll probably do a lot better than you think you're going to do. WRXs are not easy to launch, they're very easy to bog from a dig. Just practice your launch so you have the upper hand
I do agree with the whole dig thing, but I don't know of anywhere around here we can completely stop, thats all. If I could go to the track with him I would.
...or maybe we cn just have a burnout contest...
Diode Dynamics
28
May 26, 2022 12:02 PM
