Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
donut question
Old Oct 9, 2007 | 06:59 PM
Blownsvt's Avatar
Blownsvt
Default RE: donut question
just use the gas and no brakes, if you let the brake out after you start going around you should be fine.
Old Oct 9, 2007 | 07:06 PM
Morbid Intentions's Avatar
Morbid Intentions
Wash Rinse Repeat
ORIGINAL: Blownsvt
+1 I diddn't know he was braking in the middle of doing it lol
yeah that is your problem right there
Old Oct 9, 2007 | 07:49 PM
EaZy DuZ iT's Avatar
EaZy DuZ iT
noo i never touch my brakes
Old Oct 9, 2007 | 09:30 PM
The Stig's Avatar
The Stig
ORIGINAL: Morbid Intentions
ORIGINAL: geddylee
are both wheels spinning? A friend of mine has a camaro that doesn't like to do donuts in a certain direction because he doesn't haveposi-trac.
nope, our cars do one tire fires
sorry to be off topic, but your saying all 99-04 GTs dont have an LSD? wow, thats crazy. Even the V6 camaros with the Y87 package had an LSD and they had 60 less HP than the GTs.
Old Oct 9, 2007 | 10:26 PM
fast65's Avatar
fast65
Try coasting really slow (no more than 5 mph), crank the wheel to the left and hit the gas. It should do a pretty good donut.
Old Oct 10, 2007 | 08:09 AM
S8ER01Z's Avatar
S8ER01Z
Too much gas....I can do donuts with ~1500rpm and it just keeps floating around...if I lose momentum I just let off the gas a little and flutter the pedal a few times....
Old Oct 10, 2007 | 09:46 AM
ModularMax's Avatar
ModularMax
i am the doughnut king! listen itas quite easy cut the wheel fully in one direction mash the gas then she starts to turn, cut the wheel the other way at the same speed and try to feel it out, i can do about 20+ in a matter of 20 seconds
Old Oct 10, 2007 | 01:47 PM
EaZy DuZ iT
is it better to do it from stop, or 5mph roll
Old Oct 10, 2007 | 04:41 PM
johnnyv8's Avatar
johnnyv8
I'm thinking about the comment some one said about it benig an auto, maybe its shifting... Do u do ur donuts in D or 1/2 gear?
Old Oct 10, 2007 | 04:52 PM
S8ER01Z's Avatar
S8ER01Z
i had a manual valvebody so I would usually only use 1st.... stock trans I always stuck it in first and kept the rpms down.
