Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
LS1 crap!!!
Old Oct 25, 2007 | 03:54 PM
  #61
Stone629's Avatar
Stone629
Default RE: LS1 crap!!!
ORIGINAL: Stone629
The tranny maybe where we are having a miscommunication. I have only had auto LS1s and have never witnessed a 6-spd ls1 on the dyno. I know autos drain more power, but I justdidn't think it was that much. Either way, it obivously varies considerably from car to car.
Here's more of what is more common with bolt-ons and driveable cams.
http://www.youtube.com/watch?v=4L4qVjAB5jg
http://www.youtube.com/watch?v=DUYFFsKFEpk
Old Oct 25, 2007 | 04:14 PM
  #62
JD1969's Avatar
JD1969
Pro. B.S. caller outer
The trans will make a big differance as well as how big the converter is and if the converter is locked or unlocked during a dyno pull. My car made 393 when it was a 6 speed, I swapped in a 4L60E and a Yank 4000 converter. With no other changes I made 376. However the car went nearly .5 quicker. I am a cam/bolt on car and I run 11.8's @113-115 mph. Heads and short block are completley stock.
Old Oct 25, 2007 | 04:25 PM
  #63
Stone629's Avatar
Stone629
That would explain why my Z28 Dynoed so low HP wise. Full-bolt on and everything, but it was an A4 with a Raptor 3k stall. It put down a ton of torque though- 400rwtq. I never ran it with DRs to see what it could really do cause I feared the stock rear, but like you said, a good stall can knock off .5 tenths.
Old Oct 25, 2007 | 04:40 PM
  #64
WRXtranceformed's Avatar
WRXtranceformed
I've heard converters will cause you to put down really high torque numbers but lower hp numbers. Is that generally true?
Old Oct 25, 2007 | 04:45 PM
  #65
Stone629's Avatar
Stone629
ORIGINAL: WRXtranceformed
That was the case with my converter...330rwhp vs. 400rwtq.
Old Oct 25, 2007 | 05:00 PM
  #66
JD1969's Avatar
JD1969
It depends on the STR (stall torque ratio) of the converter, but generally this is true. BTW I am pulling consistant 1.5x 60's on a bone stock 3.42 geared 10 bolt. Autos are much easier on the rears
Old Oct 25, 2007 | 07:32 PM
  #67
nickdotcom2.0's Avatar
nickdotcom2.0
i also put down 393 JD, but in a completly different way
Old Oct 26, 2007 | 07:49 AM
  #68
S8ER01Z's Avatar
S8ER01Z
ORIGINAL: JD1969
Unless you do stupid **** like dry pavement doughnuts.... A LOT.
My rearend grenaded under near stock power.
StalkerGT
Nov 28, 2015 03:09 PM
ChampInSD
Oct 2, 2015 04:55 AM
yourmom6990
Sep 14, 2015 10:52 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
