Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
RACE PREP
Old Mar 24, 2008 | 05:14 PM
07lane40's Avatar
07lane40
Default RACE PREP
im getting ready to havea string of races with a few of my buddies. its on closed streets, no traffic, all is good. what should i do to prepare my car? as far as weight loss goes, i have to lose the passsenger seat, spare tire, back seat, subs, and extra junk. is there anything else that i should drop? anything else i should do in general? i wont be able to ice te intake or anything. can anyone reccommend something i can do out of my garage that will help at all?
Old Mar 24, 2008 | 05:23 PM
07lane40's Avatar
07lane40
Default RE: RACE PREP
its low speed, time attack runs, so please dont flame me about how street racing kills, i know it does, i had a friend almost die from racing a street drag.
Old Mar 24, 2008 | 05:48 PM
blue07mustang's Avatar
blue07mustang
Lower the tire pressure right before the race!?
Old Mar 24, 2008 | 05:53 PM
4.0 Stang's Avatar
4.0 Stang
Your taking out your passenger seat?
Old Mar 24, 2008 | 07:10 PM
vtmustangs's Avatar
vtmustangs
The more you pull out the less weight in the car....which equals more speed
Old Mar 24, 2008 | 07:22 PM
tmsmith's Avatar
tmsmith
Only advise I can give you is don't fill your gas tank up. 1 gallon of gasoline equals 5.8 to 6.5 lbs. You do the math.
Good luck and don't get hurt.
Old Mar 24, 2008 | 07:24 PM
jimkaray's Avatar
jimkaray
[ul][*]Unbolt or completely remove your front sway bar. That will get you better weight transfer and plant the rear tires better.[*]Over inflate your front tires for less rolling resistance.[*]I would experiment with tire pressure for the rear tires to see what gives you the best contact patch. street tires aren't meant to run at low pressure so don't go too low.[*]If you are getting good traction then run like a quarter tank of gas to save weight. If you are spinning the tires then use more gas to get some weight over the rear tires where it will help you get traction.[/ul]
Drive carefully on the way home when the racing is over! Since you've set your car up for straight line performance your car is going to handle crap now compared to what your used too. Its easy to forget that when your driving the same same car and same roads you've riden over and over, especially when pumped up from a night of racing. Remember your car isn't going react they way it has every day before when you dive into a turn hard.
Old Mar 24, 2008 | 07:43 PM
07lane40's Avatar
07lane40
well im looking for more of a road racing setup rather than a drag setup. so you reccommend higher tire pressure? like 40-45psi?
Old Mar 24, 2008 | 07:47 PM
07lane40's Avatar
07lane40
ORIGINAL: 4.0 Stang
yeah. most likely theres gonna be money on the line and theres no way im losing.
Old Mar 24, 2008 | 08:25 PM
4.0 Stang's Avatar
4.0 Stang
What kind of cars are you racing?
