Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Down shifting for power.
Old Apr 12, 2005 | 10:16 PM
Etanimulc's Avatar
Etanimulc
Default Down shifting for power.
If a car has a "top speed in gear", like Car and Driver magazine posts, of 60mph, where 60mph is where 2nd gear ends and 3rd gear begins, at the red line. If while coasting at 75mph in 5th gear, I downshift into 3rd gear and give the car full throttle and redline at say 90mph and shift into 4th gear. Will this type of downshifting and acceleration hurt my car? Hypothetically, I'm talking about a car with this kind of set up: 1st:0-35, 2nd:35-60; 3rd:60-90; 4th:90-120; 5th:120.
Old Apr 12, 2005 | 10:26 PM
dc_mann8's Avatar
dc_mann8
Default RE: Down shifting for power.
sure it will put more wear on your car than going in 5th gear revvin 1800.. but its good for it also, clean it out, and its hella fun. its not like putting your car to 5k will blow it.
Old Apr 12, 2005 | 10:28 PM
Phillyblunt474's Avatar
Phillyblunt474
ORIGINAL: dc_mann8
Correct, if you are super worried about your engine, you oculd just drop it to fourth, but if ya wanna land right in your power band then ied go to 3rd, i dont see anything wrong with it
Old Apr 12, 2005 | 11:28 PM
RollinThunder's Avatar
RollinThunder
it wont really wear out ur engine ....ur tranny and clutch will take most of the abuse...just rev match when u down shift into 3'd and u'll take most of the wear out of the clutch that way
Old Apr 12, 2005 | 11:32 PM
Guest
Guest
Posts: n/a
if you wanna replace your clutch, do it repeatedly every time you wanna gun it. It'll take a while, but it won't be pretty when the clutch finally goes.
On the other side, I love cruising at 40 in 5th gear and dropping it to 2nd.
5500 rpm = b16a fun time
Old Apr 13, 2005 | 12:10 AM
dan's Avatar
dan
Yea its not all that bad, i mean the computer downshifts in an auto and if it was really bad then it wouldn't do that. Just use it in moderations, if your redlinning every gear everytime you shift then eventually things are gonna wear faster
Old Apr 13, 2005 | 01:12 AM
JonBeast's Avatar
JonBeast
Moderator
Like they said, rev match and it will take a lot of stress off you're tranny/clutch. Just don't do it too much. We all do it though
Old Apr 13, 2005 | 01:38 AM
Mach1's Avatar
Mach1
Run that ****er to redline damnit!!! Just match the revs on the clutch and you should be fine.
Old Apr 13, 2005 | 01:47 AM
JonBeast's Avatar
JonBeast
Moderator
ORIGINAL: Mach1
My friend does that a lot.....I guess thats why he has replaced his engine 5 times, and only has 50k on the car itself. His car should be SOOO fast, but hes had to spend a lot of his money putting freakin engines in it, o well, his fault. Come on now Monster2v (thats my friend's username, lol, hahah darren) take care of that engine!
Old Apr 13, 2005 | 01:55 AM
Mach1's Avatar
Mach1
I said run your car to the redline not into it. If hes blowing engines he should try changing his oil. A lot of cars are regularly running hard and most cars will go well past 100k.
