KB GT500 vs C6Z
ORIGINAL: BicketyBam
I just had to ask Katech: Can you make 640 rwhp on the Z06 with all the bolt ons, heads and a cam. Their answer:
Their answer - not mine.
ORIGINAL: MrRogers
+1
The LS7 was meant to remain N/A. Cam and heads will have you safely 640rwhp...
ORIGINAL: AmericanMuscle4.6GT
meh.........don't go FI on the Z. Boost+LS7 = boom. not a good motor for that. n/a ftw.
How about this bargin turbo system for my Z? http://www.airpowersystems.com/corvette/tts07.htm
Can you believe that is considered "inexpensive"?
EDIT: not sure if it lists the price, but the kit is $11k plus shipping.
You're going to need boost or a lot more displacement. That would be like 720 at the crank (over 100hp/Liter).
http://www.youtube.com/watch?v=idRJ8Gjadkg
It's called the Rx 750 package. 640rwhp N/A. 7.0L
Vette doctors >>>>> Kateck
ORIGINAL: MrRogers
ORIGINAL: MrRogers
+1
Here is the rest of Katech's response.
640rwhp out of a NA 7.0L LS7 is laugh-able.
EDIT: Also it a completely built enigine. See here: http://forums.corvetteforum.com/show...740&page=2
You're joking, right?
You're starting to sound like a fanboi!
EDIT: Also it a completely built enigine. See here: http://forums.corvetteforum.com/show...1474740&page=2
ORIGINAL: MrRogers
ORIGINAL: MrRogers
+1
No seriously Vette doctors > Katech
Once again you have ran to Corvette forums trying to defuse my claim.
That was a 640rwhp 7.0L N/A LS7...was it not?[&:]
Not laugh-able at all...
Your Katech expert said that more displacement or F/I was needed...which obviously is not the case.
There was also another Vette doctors kit making 620hp - the beefed up internals.
I don't run anywhere. I visit that forum all the time. Katech claims it was bs and I believe them. They are Katech, for Christ's sake. Also, you said heads/cams will safely net 640 rwhp - no mention of a ton of internal work like that (assuming do dyno manipulation). That is a false statement. You say what needed to be done to achieve those mythical numbers.
I'm done. There is no winning with you. Heads/cams and you got 640 rwhp. I give up.
"Nope. 4.9 psi psi and you are at 625 rwhp. "
There are a few guys running 6psi and netting 560-580hp. How did someone get 625hp out of 4.9psi?[&:]
HP is HP. You can only run so much power without getting into forging the engine, be it N/A or otherwise. Agreed?
The LS7 can makes a lot of power with less boost. I agree with the max 6 psi because 6 psi on the LS7 put it in the danger zone for power on stock internals. You will be over 600 rwhp at that point, which is pushing it for the stock pistons.
But the fact remains is that you can boost an LS7 motor and you don't need a lot of it to reach the power level where the stock internals become in danger. Forge the engine and you can push over 800 rwhp with a boosted set up.
If it is even possible to make N/A 640+ rwhp in a street driven LS7, you are going to need a built engine too. See my point? It the HP level.
Now can you stop getting sh!tty with me - saying I am running to the Corvette Forums? I go there all the time and Jason from Katech is a cool guy. I am a big C6.R racing fan, so Katech carries some weight with me (and most in the Corvette community).
