Question is...if I would have trimmed some of that R/T would I have gotten a better 1/4 time? 13.926 minus .495 is 13.431. So its safe to say I would have done that 13.431 if by some miricle I cut a .000 R/T?
No, like others stated the timer starts when your front tires roll out of the stage beam. Reaction time is very important if you run heads up or bracket race. Bracket racers are running a package which is your reaction time plus how much you run above your dial. If you run 13.431 on a 13.43 dial with a .495 light your package is ((13.431-13.43) + .495) which comes out to a .496 package. If your only looking for fast times (ET only) try staging as shallow as possible. Try to just turn on (flicker) the stage light. This will give you the max roll out and quickest ET's. However in more advanced theories of bracket racing ET, RT, and 60' are all related to each other (each affect each other).
+1 on shallow staging if you are only going for ET. Like said above, this will give you some more track to actually start moving before the ET timer starts.
The only thing that's awesome about getting a good R/T is the fact that you can beat the other down the track. You may not beat his 1/4 mile time........but you'll beat him to the end of the track which means you win the race. It basically shows who the better driver is.
If you run a 12.9 and the other guy runs a 12.5 his car wins. However if you beat him down the track because you had a better R/T, but his time was better.....you won the race (since you past the 1/4 mile mark first), whereas your car lost (because your time was slower .
While everything you say is true, it only comes into play if the other guy is actually trying to race you. For example, if I am working on something specific in my cars set-up at a test and tune night, I usually don't pay any attention to the car in the other lane, in fact at test and tune I do not try for a good R/T unless I am able to get a .400 Pro-Tree, for me practicing on a .500 Sportsman tree is useless. Claiming a win on car that is not actually racing you is kinda ricer
