Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Tire Q
Old Aug 24, 2008 | 07:12 PM
Sarge_13's Avatar
Sarge_13
Originally Posted by 99GTvert
Just one thing: don't mash the gas (meaning don't floor it), instead just bring the RPMs up to like 5k while holding the brake pedal, then let go of the clutch. Your car may want to move forward, so adjust the brake pedal. If the car wants to bog, feed some more gas.
Any reason why? Just curious, never launched a stock-ish GT on DR's.
Old Aug 24, 2008 | 07:16 PM
Stkjock's Avatar
Stkjock
Retired Mod
Originally Posted by dacop
I plan on putting the new DRs on cheap rims as downriver1 suggested.
Good idea
I have 18x9s on the CS with 3.55. I have to drive about 50 miles to the track so I am leaning towards the Nitto 555r's for longer lasting tires...or maybe the BFGs.
If you have the OEM wheels they are only 8.5" wide. Nitto's for track only use are a big mistake IMO and they dont make a tire in 18" approved for less then a 9.5" rim. IMO that is too much for the stock size.
BELIEVE ME I'VE SEARCHED FOR A YEAR AND A HALF!
For the stock rims the 265/40/18 is the best choice of DR, and now only MT makes it.
What about the burnout? I have a 5-speed with no line lock. How hot do I need to get these DRs and how would I do this without locking them up?
depends on which ones.... the Nitto needs a really good burnout, the MTs a good first and then just a bit for the added passes.
Old Aug 24, 2008 | 07:22 PM
99GTvert's Avatar
99GTvert
is my username.
When you suggested to mash the gas, I would imaging at that point for the burnout while being in neutral you would be bouncing the rev limiter.
Old Aug 24, 2008 | 07:38 PM
dacop's Avatar
dacop
If I do indeed have 8.5" rims, wouldnt I be better off with the MT P245/40R18 if I stay with that same size rim?
Old Aug 24, 2008 | 07:51 PM
Stkjock's Avatar
Stkjock
Retired Mod
YOU DO! CHECK YOUR DOOR JAM!
wouldnt I be better off with the MT P245/40R18 if I stay with that same size rim?[/QUOTE]
NO! Its only a 25.8" tall tire, the 265/40 is a 26.5 tall tire, closet to stock. additionally you want to put the most rubber (generally) on the road as you can
Old Aug 24, 2008 | 08:14 PM
dacop's Avatar
dacop
Noted! Hey...thanks for all the help! I will go with the MT 265/40/18. ok...so now I need a cheap rim....any suggestions?
Old Aug 24, 2008 | 08:56 PM
Stkjock's Avatar
Stkjock
Retired Mod
well now I'm confused... if your gonna get a set of 17s to race only, then dont spend the $ to get the DRs on the 18s - unless u can use them 24/7/365 and u dont use the car in rain/snow.
for 17s, u can get OEM takeoffs 17x8 here:
http://www.newtakeoff.com/mustangwhe...llitteach.aspx
or get some 17 x 9s here:
http://www.americanmuscle.com/2005-a...x9-wheels.html
the 17x9 will give you a better tire choice
if your patient u could probably find them on ebay/craigs list from time to time for less
Old Aug 25, 2008 | 05:33 AM
downriverT's Avatar
downriverT
17x9 rims are very common and can be found for reasonably cheap. Thats what I run with hoosier dr's. But you can run mickeys, hoosiers, bfg, and m&h will fit that rim. Don't speak of nitto's again and you will be in the right direction.
Old Aug 25, 2008 | 12:30 PM
dacop's Avatar
dacop
Basically all I will be doing is taking off my rear stock 18s the same day of the race and putting on new DRs for the drive to the track and to race. When I get home, off they come and back on with the 18s.
1. 17x9 a wiser choce then 17x8?
2. It will be ok to run 18s in front and 17s in rear?
3. Best tire choice for my 17xX setup?
Thanks
Old Aug 25, 2008 | 12:48 PM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
I'm running a 28 x 13.50 on a 15x8 tire. It bulges, but it fits still
