Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
suspension question
Old Dec 11, 2008 | 10:42 PM
PLstang's Avatar
PLstang
Yeah it's a three link. With two lower control arms and one centrally mounted upper.
The 05+ are much stiffer and the only chassis stiffening necessary is the torque box stiffener and you don't need that until the power gets up there, say 650rwhp and above.
Old Dec 11, 2008 | 10:52 PM
PLstang's Avatar
PLstang
OP, yes your car can benefit from suspension work. It doesn't matter how much power you make if you can't hook it up.
How much work needs to be done is dependent on how the car is running. You need to have some one video the car on launch. It's hard to determine what the car is doing exactly while driving it.
We just went from a 9.57 to a 9.21 on my car. The biggest change was a simple tweak of the suspension. We found the problem watching video of the car launching in slow motion.
You may not have wheel hop......but are you hazing the tires? Maybe you're unloading the tires 30' out because of the shocks, there are a lot of different things these cars (S197's) will do. I suggest doing a little research into exactly what the problem your having is instead of just throwing parts at it.
That just my .02
And yes I agree your car should 60' a little better.
Old Dec 12, 2008 | 04:55 PM
graygt07's Avatar
graygt07
i will be at the track on new years day and i will try too take some video and see what i can see. thanks
Gene K
Oct 21, 2015 11:37 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
degner122
Sep 16, 2015 07:09 AM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
