im seeing low 12's consistently high 11's with everything going perfect.
I have $1 that says he won't do better than a 12.2 . I don't think he has enough suspension to hook up good on those nittos, and I don't see that he has a stall. I think his 60' is going to suck but I may be wrong. I'd think with a stall, either better tires or drag type suspension he might go 11's but not as it sits.
Also the fact that he thinks low 11's is possible tells me that there is a lack of track experience. But like I said before I may be wrong.
i dont see you making enough power to be in low 11s. I think you should lower your expectations and try to hit 11s first then work your way down. Stall and slicks will be a must
