Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Wheel/Tire selection
Old Mar 5, 2009 | 02:53 PM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Default Wheel/Tire selection
I am looking to get wheels and tires here shortly, maybe with my tax refund. I want to know if it makes a difference in trap time and speed if I get 17 vs 18" wheels? I was thinking of getting 17x10 in the rear and 17x8.5 or 9 up front. I just want to know if that helps or hurts. I was thinking it would be less wheel weight with a 17, but then I don't know if the fact that it is a smaller height will make a difference too.
Old Mar 5, 2009 | 02:59 PM
83gtragtop's Avatar
83gtragtop
You are worried about tire height not wheel height. Changing wheel size shouldn't change your tire height if by the proper tire with a smaller sidewall. POST THIS IN THE WHEEL/TIRE SECTION.
Old Mar 5, 2009 | 04:05 PM
ChalknCover
Sgt. Killjoy
I know tire size makes a difference, but wheel size doesn't at all? If not, then I am not worried about it, I have a good idea of the tires I would get for it then.
Old Mar 5, 2009 | 06:16 PM
94Blk5.0's Avatar
94Blk5.0
It would probably be best to get whatever kind of wheels you like for the street, then take two of the stock wheels, and mount some DR's on them for track performance. Keep the overall tire height the same for street use. Deep dish set-ups look great btw.
My $.02
Old Mar 5, 2009 | 06:25 PM
lbballin9's Avatar
lbballin9
The staggered look is really nice! 10 in the back is pretty wide though! 8X5 or 9's are pretty good and not too crazy
Old Mar 5, 2009 | 06:47 PM
Soldier GT's Avatar
Soldier GT
Talking
Man the 10's are nice. I'm running 18X9's front and 18X10's rear.
Old Mar 5, 2009 | 06:56 PM
lbballin9's Avatar
lbballin9
I wish I had enough money to get a good set of tires and rims. I definitely need some cause mine aren't working for traction worth poo.
Old Mar 5, 2009 | 07:13 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
It won't change the tire height much if done right, but the larger wheel/tire combo will weigh more and this is un-sprung rotating weight, so could/will slow the car down a bit.
Old Mar 5, 2009 | 09:33 PM
Stkjock's Avatar
Stkjock
Retired Mod
/\ I'm with JD
in generally its best to run the smallest tire you can that will hook with your cars mods, if they are track tires only(?) then a 15" would be the best.
the issue with the larger diameter rim is the weight is further from the center of the wheel and takes more power to turn and as a result you lose ET
Tivo304
Aug 28, 2023 12:19 PM
carid
Jul 8, 2016 09:55 AM
xbmx89
Texas Regional Chapter
Nov 10, 2015 10:43 PM
JoshyGT
Sep 7, 2015 02:04 PM
Steve@CJPP
CJ Pony Parts
Sep 3, 2015 11:43 AM
