Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
New Best
Old Mar 12, 2009 | 10:01 AM
sactown's Avatar
sactown
Default New Best
Went to the track for the first time since Jan 1st, and the first time with my new setup.
Results:
11.933 @ 117.468
1.851 60ft
Pretty happy with those numbers, if I can drop my 60ft into the low 1.7's or high 1.6's that should put me in the 11.7's or lower. Did manage to kill a vette along the way, which always brings a smile to my face.
Here are the full results.
Only got in 5 runs but here is the break down.
Run 1
Reaction: .298 (sucks!)
I1 1.940
l2 5.454
l3 8.264
l3 (mph) 89.308
l4 10.626
E.T. 12.606
MPH 114.269
(hit the rev limiter in every gear)
Run 2
Reaction: .316
I1 1.774
l2 5.039
l3 7.715
l3 (mph) 93.059
l4 10.012
E.T. 11.952
MPH 117.203
Run 3
Reaction: .075
I1 1.928
l2 5.124
l3 7.873
l3 (mph) 93.277
l4 10.175
E.T. 12.114
MPH 116.454
Hit rev limiter in 3rd
Run 4
Reaction: .104
I1 1.941
l2 5.233
l3 7.903
l3 (mph) 93.150
l4 10.195
E.T. 12.127
MPH 117.159
Run 5
Reaction: -.034 (red lighted)
I1 1.851
l2 5.084
l3 7.730
l3 (mph) 93.556
l4 10.011
E.T. 11.933
MPH 117.468
Old Mar 12, 2009 | 12:10 PM
AmericanSpeed's Avatar
AmericanSpeed
What's new about this setup? Man, your 60' were all over the place. Were you trying out different things? How was the weather, you think you may be able to trap anymore? I think you can do 11.5 with a good 60 and another mph.
Old Mar 12, 2009 | 12:56 PM
bolivianpimp's Avatar
bolivianpimp
+1 on the complete setup, do you have tires?
Old Mar 12, 2009 | 01:25 PM
sactown's Avatar
sactown
New setup: 3.4 pulley, new tune (which still needs a little work car is rich), larger heat exchanger. Weather was in the mid 50's, tire are MT ET Streets 275/45/17's at 16-15 psi. Car is a stick and my differential is offically dead, only one tire spins on burn out. Launched anywhere between 2000 and 3500 rpm tires still spun pretty bad off the line which is why my 60' is all over the place, only suspension mods are BMR billet aluminum LCA's.
I am hopping from 11.5-11.6's
Old Mar 12, 2009 | 01:41 PM
bluebeastsrt's Avatar
bluebeastsrt
Congrats. Looks like the car still has plenty left. The diff. is going to hold you back. Probably time for more suspension mods.
Old Mar 12, 2009 | 01:53 PM
sactown's Avatar
sactown
Car's going in tomorrow for the diff. Depending on the tax return I might be shopping for some suspension mods. Any suggestions?
Old Mar 12, 2009 | 02:30 PM
bluebeastsrt
For your car I'd probably do LCAs first. Maybe some adjustable shocks to assist in weight transfer. Maybe some subframe connectors. Those will make your street ride a little more ruff though.
Old Mar 12, 2009 | 05:48 PM
sactown's Avatar
sactown
Got the LCAs already. I was thinking adjustable uca, slit change to pinoin angle and I good set of adjustable shocks.
Old Mar 12, 2009 | 05:52 PM
87slutstang's Avatar
87slutstang
where are you from sactown?
i would get adj. shocks and subframes!
best improvement i've done to my car, but is is a convertible fox!!!!!
Old Mar 12, 2009 | 06:00 PM
AmericanSpeed
I've been running my ET Streets at 14 psi lately. I also dump the clutch at around 3500-4000 rpm and rarely spin, I think I should be coming out even harder. When I first got the blower, I was coming out really easy, around 2-2.5k rpm, but would spin like crazy once I rolled into the throttle. I think the ET Streets work better when you shock them with a higher rpm clutch drop rather than an easy one and then getting into throttle.
