Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
drag tips?
Old May 12, 2009 | 04:59 AM
fordracer666's Avatar
fordracer666
Default drag tips?
hey guys just got my 06 gt , it has a c&l intake and 93 bama tune. udp ,bbk tbody,full exhaust with high flow cats(no headers yet)borla stingers , 355 rear, lower control arms,and 285/40/18 eagle f1s. i did search before posting.
ok heres my questions
i need some tips for the track ? ive been to track tons of times with my other cars. but how should i be launching and what rpms should i shift her at?
one more question whats you 1/4 guess with my mods?
Old May 12, 2009 | 05:54 AM
Stkjock's Avatar
Stkjock
Retired Mod
https://mustangforums.com/forum/stre...ow-to-faq.html
Old May 12, 2009 | 10:23 AM
ski's Avatar
ski
Great advice in Stkjock's link.
A few additional suggestions:
- Most S197 GT owners launch anywhere from 2500-3500 rpm while slipping the clutch to prevent engine bogging and excessive tire spinning.
- Disconnect the battery for at least 30 minutes to wipe out the PCM's adaptive learning when you arrive at the track. This will increase your engine's performance if you had done a lot of conservative driving in the recent past. (Note: You may notice erratic idle speed after doing this. Nothing to worry about. It will go back to normal after 20-30 miles of driving.)
- After reconnecting the battery, set the rev limiter to 7000 rpm with your tuner, and shift at 6500 rpm. This should allow you to cross the finish line in 3rd with your 3.55 gears, and thus avoid a 3-4 shift that can reduce the car's momentum. It also prevents the throttle body from slowly starting to close at 300-400 rpm before redline, which reduces power.
- Heatsoak kills our engine's power. Allow it to cool down whenever possible.
- Lowering rear tire pressures to 22-26 psi may improve traction.
Good luck, and let us know how it goes.
Old May 12, 2009 | 05:50 PM
fordracer666
Default drag
thanks for the great tips guys i really appreciate it!! anyone have any guess on what i should run??
Old May 12, 2009 | 07:53 PM
moosestang's Avatar
moosestang
13.1@107mph
Try launching at 2000 rpms at first.
Old May 12, 2009 | 10:33 PM
fordracer666
Default drags
thanks again for tips and help guys
FivePointToTheOh
Mar 9, 2020 10:26 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 10, 2015 08:39 PM
