Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Looking for an ET Estimate
Old Jul 15, 2005 | 04:41 AM
comp178z's Avatar
comp178z
Default Looking for an ET Estimate
I am looking for a quick estimate of what my car should run in the 1/4 and 1/8th mile before I take it to the track. I have drag raced for 10 years so driving it will not be an issue. Hooking it up is a different story all together. Anyway, here is the info...
It is a 2003 Saleen S281, Motor has been bored and stroked to 305 inches and is running a NOVI 2000 Reverse Rotation supercharger. The heads have been CNC machined, it has 72# injectors, Weldon Pump, Sheet Metal Intake.... etc. It has been dynoed at 600.5 Rear Wheel Horsepower @ 6300 rpm and 522 Ft-Lbs @ 5700 rpm on pump gas. The trans is a complete aftermarket 5-speed, the rear has 3.73 gears, and it has an aluminum drive shaft. Suspension is stock saleen so hooking up may be a big problem...
What do you think I would see for times with both street tires, and slicks in the 1/4 and in the 1/8th.
Old Jul 15, 2005 | 07:35 AM
blownstanger's Avatar
blownstanger
Default RE: Looking for an ET Estimate
QUICK>>>Probably...being a sceptic...low 12's...maybe if ur lucky high 11's.
Old Jul 15, 2005 | 07:56 AM
comp178z's Avatar
comp178z
Sceptic of what?
Old Jul 15, 2005 | 08:03 AM
comp178z's Avatar
comp178z
Dyno Sheet...
http://i7.photobucket.com/albums/y27...Saleendyno.jpg
Old Jul 15, 2005 | 08:20 AM
blownstanger
FORGET THAT REMARK (SCEPTIC)*
Old Jul 15, 2005 | 09:09 AM
comp178z's Avatar
comp178z
No Problem....
Also, here is a picture of the car
http://i7.photobucket.com/albums/y27...l/DSCN0373.jpg
Old Jul 15, 2005 | 01:07 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
That dyno sheet has a nice curve to it. Like you said though hooking up will be the major problem. I am going to say on a street tire you will see mid 12's but on a slick it will be low 11's, now with better suspension I don't see why 10's would be a problem.
Old Jul 15, 2005 | 05:27 PM
757GT's Avatar
757GT
I ♥ Acer
I'm with JD.
Old Jul 15, 2005 | 06:22 PM
firemedix911's Avatar
firemedix911
11's with good tires and with better susp 10 like jd said. It seems like you have a bad as car dude. Congrats.
Aggiebq86
Sep 4, 2015 12:20 PM
kdryan
The Racers Bench
Aug 22, 2015 02:14 PM
svtrosey
SVT Forums
Aug 15, 2015 09:09 PM
James Watson
Aug 6, 2015 06:42 AM
