Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
C5 Z06... Round 2!
Old Oct 29, 2009 | 12:39 PM
  #31
Grabber's Avatar
Grabber
Originally Posted by Riptide
lol 3800 pounds? Unless the guy needs weight watchers I don't think so.
You don't think his GT with his sound equipment and the driver don't weigh close to 3800lbs?
BASE WEIGHT is 3500lbs. 150 for driver, approx 100lbs for sound system stuff, hmmm. 3750 right there. Assuming he weighs 150lbs.
Get out more. Out of the 8-9 Forums I post daily on, which involves a ton of F-bodies, with no weight reduction, C5Z race weight is around 3300lbs with the average driver.
FYI- C5Z's weighed 3115 straight from the factory.
I doubt every driver is 200+ lbs, nor is the average driver.
Old Oct 29, 2009 | 12:43 PM
  #32
Riptide's Avatar
Riptide
The BASE WEIGHT is 3483 vs. 3116.
Regarding the sound system - it slipped my mind. I'm sure it does add some weight. He should just ditch his spare tire.
Old Oct 29, 2009 | 12:45 PM
  #33
Grabber's Avatar
Grabber
WOW 17 LBS!!!!!!
THAT IS LIKE 8 TENTHS OF A SECOND!!!
Either way,
3300+-LBS with 350-360 RWHP> 3700+-LBS with 280-290 RWHP
The spare is good for about 30 lbs. Pretty sure his AMP alone is that much. Even without the Sound System all together, there is still over a 350lb weight difference.
Old Oct 29, 2009 | 12:58 PM
  #34
Riptide's Avatar
Riptide
Oh Jesus Christ.
I was just trying to inject a little more precision into the figures. **** me for forgetting about the sound system. :/
Old Oct 29, 2009 | 01:00 PM
  #35
acarzt's Avatar
acarzt
My sound system doesn't weight 100 pounds lol The amp is pretty small and light even tho it pushes pretty good power. The sub and box are pretty heavy tho... but all together it probably only weighs about 50lbs or so. Plus the box sits over the rear right tire, so it has dual function lol...
None of all this really matters... Look at the gearing...
Gear Ratio Mph/1000 rpm Max. test speed
I 2.97 7.4 48 mph (6500 rpm)
II 2.07 10.6 69 mph (6500 rpm)
III 1.43 15.3 100 mph (6500 rpm)
IV 1.00 21.9 143 mph (6500 rpm)
V 0.84 26.1 168 mph (6450 rpm)
VI 0.56 39.2 155 mph (4000 rpm)
I raced him from 60 he would of had to of started in 3rd and would have been just out of his powerband which gave me a quick jump... but I nailed the rev limit and he went on by... no idea how bad that one would have been. He would have started at about 3900 rpms, peak torque hits at 4800rpms, and peak HP @ 6k
Went again from 50. He could have gone to 2nd but he more than likely did not cuz I did not hear a shift all the way to 100. He would have DEFINITELY been out of his powerband, making it much easier for me to get a jump. He would have been starting at about 3250rpms. at 80mph he would be at 5200rpms, just got to where all the power is and he was already working on passing me.
Old Oct 29, 2009 | 01:32 PM
  #36
Grabber's Avatar
Grabber
Oh Jesus Christ.
Relax sweetcheeks, don't get all emo now.
Just saying.
Nonetheless, I race cars out of my power, have better gearing, more power, etc. and still pull.
This guy was ****ing with you, get over it.
If it was a real race, where he was into it, you would be VERY far behind him.
Old Oct 29, 2009 | 01:40 PM
  #37
acarzt's Avatar
acarzt
Just saying.
uhhhh, that's kind of what i've been saying this whole time, I said he could have gone into a lower gear... but nooooo that's not possible he had to of beat my by a billion buslengths no matter what!
Jeez man, you talk about us S197 dudes being nutswingers that our cars are almighty and I openly admitted from the beginning he could have gone to a lower gear. But you're over here swinging from the corvettes nuts saying there is no way it ONLY beat me by such a small amount. God forbid anything with an LS motor in it doesn't beat an S197 by a football field cuz everyone is gonna call BS and start massaging the LS motors nuts!
Old Oct 29, 2009 | 01:44 PM
  #38
Grabber's Avatar
Grabber
Not really.
I've been in the racing game a lot longer than most, and probably longer than you (about 10 years) and have raced plenty, and have plenty of friends with them.
I would hope a lighter 5.7 V8 higher powered car would beat a lesser powered car with more weight by a good amount.
Also, you have been arguing that you wouldn't need a big shot of nitrous or an S/C to beat one. That is gay.
I am not a nutswinger, I just know what most cars can and cannot do, and don't just race one, and immediately assume the outcome.
Old Oct 29, 2009 | 01:49 PM
  #39
Stone629's Avatar
Stone629
Whats the final gear ratio on those C5 Z06s?
Old Oct 29, 2009 | 01:52 PM
  #40
acarzt's Avatar
acarzt
Not really.
No, you misunderstood what I said about the 150 shot. I said I wouldn't need it to LOSE to one, not to BEAT one. I lost the race, and at the beginning you asked if I had a 150 shot, and I said I don't need that to lose a race... In other words... I can lose a race just fine without it... whatever anyway... I'm well aware that if the Z06 was giving it his all, the results would have been different. It was pretty obvious when I pulled that he wasn't in his power, so probably not in the gear he needs to get the most out of his engine. He clearly has more power because he quickly stopped my pull and started pulling himself. I even said in my VERY FIRST, and Unedited post that he was probably too lazy to downshift. And then I jokingly implied my 2nd gear was amazing.
Don't take what I say out of context. I know that it would take a lot of power to beat one. It would take full bolts ons and cams w/an awesome tune just to stay close to one that is really trying.
