Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Drag Rules?
Old Sep 21, 2005 | 12:50 PM
LIVIN_LEGEND's Avatar
LIVIN_LEGEND
Default Drag Rules?
im going to the drag strip for the first time soon, cecil county dragway in maryland and i expect my 2002 GT Manual to run high 13s. i remember reading somewhere if you run 13.99 or better you need a helment is this true? and if it is what helmet do i get and where?
Old Sep 21, 2005 | 01:01 PM
Sidewayz6.0's Avatar
Sidewayz6.0
Default RE: Drag Rules?
You need a helmet running 13.99 or faster on any NHRA track. The helmet must meet SNELL M85, M90, M95, SA85, SA90, SA95 or K98 standards.
You can usually buy one at a performance shop, but you're better off buying one online and saving a ton of money as some of these can be quite expensive.
Are you sure the track is NHRA sanctioned? If it's not, they probably won't require you to have a helmet for high 13's.
Old Sep 21, 2005 | 01:06 PM
LIVIN_LEGEND
so where do i get this helment online
Old Sep 21, 2005 | 01:07 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
what he said except that next year NHRA is changing the helmet standards M95 and lower will no longer be current. Get the highest rated one you can afford, it will stay current longer. It sucks now I need a new new helmet and mine is only a few years old
Old Sep 21, 2005 | 01:09 PM
JD1969's Avatar
JD1969
ORIGINAL: LIVIN_LEGEND
You can order them at Summitracing.com or Jegs, but go to a local motorcycle dealer to try some on and get an idea of the size you want.
Old Sep 21, 2005 | 01:10 PM
Sidewayz6.0
I would try Google first, but I know that places like Summit and Jeg's carry them. Although probably not the cheapest available.
nanaki's Avatar
nanaki
Retired MF Moderator
what's the requirements for 14s, 13s, 12s, etc?
Old Sep 21, 2005 | 01:15 PM
LIVIN_LEGEND
would a motorcycle helment work that i could borrow from a friend, since i will only go once or twice
Old Sep 21, 2005 | 01:17 PM
Sidewayz6.0
As long as it meets those standards listed above.
Old Sep 21, 2005 | 01:21 PM
LIVIN_LEGEND
if i have to wear a helment and run a 14.1 or something im gone to run my car into a wall just to raise the standards
