Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Track time..Video inside!!
Old Jul 16, 2012 | 10:34 AM
  #51
perfect.disguise's Avatar
perfect.disguise
See it's a NHRA track. Do they not have track standards? (serious question)
Old Jul 16, 2012 | 11:35 AM
  #52
uberstang1's Avatar
uberstang1
Chupacabra
Which track standards are you curious about?
Old Jul 16, 2012 | 11:40 AM
  #53
uberstang1's Avatar
uberstang1
Chupacabra
Here are the NHRA and IHRA track specifications, what part of this thread has any of these in question? A matter of fact they re did the track last year up to the 1/th mile, one of the better hooking tracks in the division and its one of the best prepped.
PHASE IV: DESIGN SPECIFICATIONS - DRAG STRIP REQUIREMENTS
Requirement IHRA - National NHRA
Facility Size (Dependent on Layout) 200 - 300 Usable Acres Min 100 Acres 138 Acres +
Width (Recommended) 60' 60' (58' + 1' Walls) 60' (58' + 1' Walls)
Width (Minimum) 60' 60' 60' (58' + 1' Walls)
Length (Minimum) Start-Finish 4000' 4000' 4904'
Length (Recommended) Start-Finish 4500' 3960' 4904'
Run Off (Recommended) 200' Not Specified 278'
Run Off (Surface) Sand Not Specified Gravel
Turn Off Gates (1st Used For Emergencies) Not Specified 300 Beyond 1/4 mile 301
Turn Off Gates (For Racers) Not Specified 1320 Beyond 1/4 mile 1321
Turn Off Gates (Amount) Not Specified 3 3 + 1 At The End
Concrete Launch Pads (At Starting Line - Min) 300' 330' 1320'
Concrete Launch Pads (At Starting Line - Rec) 750' 660' (1/8 mile) 1320'
Burnout Box (Location) Not Specified 90' Behind Starting Line 105' Behind Starting Line
Burnout Box (Size) Not Specified Not Specified 10'x6'
Christmas Tree (Location) Not Specified 42' In Front Of Starting Line - 20' ?? 41'8"
Retaining Walls Start-Finish (Width) Not Specified 1' 1'
Retaining Walls Start-Finish (Height) 28" - 1000 ft / 38" To the End Not Specified 28" - 1000 ft / 38" To the End
Retaining Walls Start-Finish Concrete Wall - Double Stack Guardrail Highway Type Concrete Wall
Retaining Walls Start-Finish Adjacent To Track - No Openings Not Specified Adjacent To Track - No Openings
Guardrail Posts (Max Distance) 12'6" Not Specified 12'
Guardrail Posts (Center) 6'3" Not Specified 6'
Guardrail Posts (Max Gap - Under) 2" Not Specified 1"
Staging Lanes (Minimum - Amount) 8 Lanes 6 - 10 Lanes 7 Lanes
Staging Lanes (Minimum - Length) 300' 200' 500'
Staging Lanes (Minimum - Width) Not Specified 10' 9'6" Width + 6" Painted Lines
Crowd Control Fence (Location) Pits - Track - Return Road Pits - Track - Return Road Pits - Track - Return Road
Crowd Control Fence (Location) Not Specified 60' - 80' From Track Minimum
Crowd Control Fence (Location - Burnout - 1/8) 25' Not Specified 25'2"
Crowd Control Fence (Location - 1/8 - Shutdown From Retaining Walls) 50' Not Specified 50'
Crowd Control Fence (Minimum - Height) 4' Not Specified 4'
Perimeter Pit Fencing (Fans & Racers) Recommended Not Specified Installed
Racing Surface (Desired) + / - 1/10" Less Then 1% Grade Change + / - 1/10"
Grand Stands (Minimum - Spectators) 10,000 (State Approved) Not Specified 30,396 State & Federal Approved
Grand Stands (Recommended Angle) Not Specified 10 Degrees 10 Degrees
Grand Stands (Recommended Height) Elevated Above Guardrails Elevated Above Guardrails 4'
Pit Area (Racing Rigs) 800 600 791
Pit Area (Bathroom) Not Specified 2 (One having Showers) 7 (One has Showers)
Pit Area (Minimum Racing Rigs - Paved Parking) 200 out of 800 (5 Acres) Not Specified Fully Paved
Pit Roads (Width) 30' Not Specified 40'
Concession Stands / Restrooms Meet Health Departments Specs Main One Behind Grandstands Meet Health - Inside Grand Stands
Timing Tower / Control Tower Meet the needs of Operations 2-3 Floors (Min) Meets Operations Needs - 3 Levels
Timing Tower - (Angle to The Track) Not Specified 70 Degrees (Jet Cars) 0 Degrees- Raised Platform
Timing Tower - Press Room Suggested Not Specified In Tower
Timing Tower - Elevation Not Specified Minimum 15' 60'
Timing Tower - Working Area Not Specified Minimum 12' x 10' 60' x 18'5"
Timing System Compulink Not Specified Compulink
Fire Equipment (Minimum In Pounds) 50 lbs Not Specified 250lbs
Fire Crew Personal Trained Must Be Present Not Specified 1 In House & Leesburg Fire Dept
Ambulance (Minimum - Amount) 1 Not Specified 1 In House & Leesburg EMT's
Lighting Track, Parking, Pits, Staging Lanes Not Specified Track, Parking, Pits, Staging Lanes
Lighting (First 1320) Distance Between Not Specified 150' 150'
Lighting (Shutdown) Distance Between Not Specified 200' 200'
Lighting (Type) Not Specified 3x - 1000 Watt - 480 Volt - Metal Halide 3x - 1000 Watt - 480 Volt - Metal Halide
Lighting Height of Poles Not Specified 60' 70'
TV Production Truck Hospitality (Minimum) 1 - 220 Volt, 220 Amp Power Not Specified 4 - 220 Volt, 220 Amp Power
Telephone Hook ups (Minimum) 25 Not Specified 75
Telephone Hook ups (Requirements) 50 Not Specified 75
ET Booth (Location) Return Road - Adjacent To Shutdown Not Specified Return Road - Adjacent To Shutdown
Scales Return Road - Adjacent To Shutdown Not Specified Return Road - Adjacent To Shutdown
Impound Area (Inspect Vehicles) Required Not Specified Return Road - Adjacent To Shutdown
Premium Parking for Guests and Sponsors Required Not Specified Adjacent To Handicap Parking
Manufacturers Midway (Display Products) Required Not Specified Yes
Fuel Center Recommended Recommended (Nearby Staging Lanes) Return Road - Nearby Staging Lanes
Compressed Air Not Specified Recommended (Away From Fuel Center) 3 Locations on East Side of Paddock
Scoreboards (Elapse Time & MPH of Each Lane) Required Daktroniks LED Daktronics DR-4883-36-11
Public Address System Required Not Specified Installed
Race Track Surface 1st Layer (Lowest) Not Specified 14" Lime 14" Lime
Race Track Surface 2nd Layer Not Specified 10" Soil Cement 10" Soil Cement
Race Track Surface 3rd Layer (First 1/8) ???" Concrete 9" Concrete 5000psi Minimum 9" Concrete 7500psi Minimum
Race Track Surface 3rd Layer (1/8 to Shutdown) Not Specified 3" Polymer Asphalt Mix 3" Polymer Asphalt Mix
Track Direction Not Specified West - East West - East
Return Road (Width - Minimum) Not Specified 24" Wide + 12' For Time Slip = 36' 24 Wide + 12'6" Express Lane
Return Road (Width - Minimum) Not Specified 20' Minimum 24 Wide
Return Road (Distance From Barrier - Minimum) Not Specified 100' 167'10"
Return Road (Protection) Not Specified Not Specified Concrete Retaining Wall - With Fence
Parking Area (Patrons - Minimum) Not Specified 2000 Spaces A: 3031 B: 5733 C: 20000+
Pull Boxes Not Specified 25' - 30'
Old Jul 16, 2012 | 01:47 PM
  #54
perfect.disguise
About it not having an incline.
Old Jul 16, 2012 | 02:05 PM
  #55
uberstang1's Avatar
uberstang1
Chupacabra
I failed to see anything about it in NHRA track guidelines.
Old Jul 18, 2012 | 12:37 PM
  #56
CobraFrenzy's Avatar
CobraFrenzy
^^ thx for the education lol
PaulH2
20
Jan 31, 2016 09:48 AM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
