Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Preloading?
Old Oct 3, 2005 | 01:03 AM
*Blk_96_Stang_GT*'s Avatar
*Blk_96_Stang_GT*
Default Preloading?
Ok my friend says tht holding the brake and slightly getting on the gas up to 1500-2000rpms and then luanching is just as bad a neutral drop. I think hes crazy, but whos right?
Old Oct 3, 2005 | 01:11 AM
lxstang5_0's Avatar
lxstang5_0
I ♥ Acer
Default RE: Preloading?
ORIGINAL: *Blk_96_Stang_GT*
I never said tht it is just as bad as a neutral drop, i said tht it will do basically the same things because it will ruin the 1st gear and the torque converter, but it will ruin the tranny eventually.
Old Oct 3, 2005 | 01:36 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
It would take a long time to mess the tranny up beyond a driveable condition just by preloading the suspension before take off. You can actuall power brake an auto all you want, it would still take a good bit of time to ruin the tranny.
Old Oct 3, 2005 | 01:45 AM
96SilverLT1's Avatar
96SilverLT1
does it hurt? yes.
will you ever see a problem as a result from it? doubtfull
Old Oct 3, 2005 | 02:26 AM
dc_mann8's Avatar
dc_mann8
haha i like the whole question and answer routine u have there 96
Old Oct 3, 2005 | 11:55 AM
96SilverLT1
Why thank you
Old Oct 3, 2005 | 12:19 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: lxstang5_0
It really won't do any damage unless you do it every time you drive the car. Actaully preloading like that is easier on the u-joints and rear end as there is not as much shock. It won't ruin first gear and it won't ruin the torque convertor, cars are not made out paper and twigs, they can take quite a bit of abuse.
Old Oct 3, 2005 | 02:40 PM
tinman's Avatar
tinman
True, when you have the converter loaded in low gear you are building up heat in the trans/converter. Tha's why I've always used a trans cooler on every car I've ever raced.
Failure of converter/trans? Nope, not if they are in good shape to start with........
Old Oct 3, 2005 | 03:04 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
I think physical violence by sledgehammer is the only thing as bad as a neutral drop on an auto tranny.
TASSY5
Feb 6, 2008 09:38 PM
ford_jake2003
Sep 28, 2007 04:01 PM
jmk3
Feb 18, 2007 02:53 PM
silver05gt1
Sep 1, 2006 10:49 PM
