Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Traction issues at strip!!
Old Jul 24, 2013 | 09:38 PM
  #21
jeff37110's Avatar
jeff37110
I will be running Friday..I'm gonna take my et streets and borrow my buddies too in case I start spinning again..
Old Jul 25, 2013 | 09:27 PM
  #22
UPRSharad's Avatar
UPRSharad
Former Sponsor
Originally Posted by jeff37110
Im running the fixed length upr control arms,but have the double adjustables on the way..Maybe its in my pinion angle,but I just dont see it making that much difference..On the spring rate, I did have 12inch 175rate springs and my car would bottom out on the street..Went with the 250 spring and it fixed my ride problem..
I don't see why it would bottom out on 12-175s. Maybe I'm missing something here... but since you are running UPR Products suspension, you are welcome to call us at 561.588.6630, and if you call between 830-330 Eastern time, you can talk to Jeremy for tech help. He's one of the best in the industry.
Old Jul 25, 2013 | 10:24 PM
  #23
jeff37110's Avatar
jeff37110
I talked to him before..I went through hell trying to figure it out..I changed caster/camber plates,struts,ball joints..It didnt help so I called and they recommended trying that spring rate..It fixed the problem so no complaint there..but that 12 175 spring is what my tuner recommended for street/strip..
Old Jul 27, 2013 | 09:45 AM
  #24
jeff37110's Avatar
jeff37110
Well I ran a little better last night..I removed my front sway bar..Still spinning really bad in first gear though..I ran 7.66 at 99.4 mph with a 1.79 60 ft...Hope to get my double adjustable uppers on..Then maybe call upr and order a different front coilover spring more drag strip friendly..I let a good friend of mine drive the car last night..He said the front end is way to stiff and is not tranfering weight very good...
  #25
jeff37110's Avatar
jeff37110
Also went to a better track..So thats probably why my times were better..
Old Jul 29, 2013 | 09:32 PM
  #26
UPRSharad's Avatar
UPRSharad
Former Sponsor
Yeah, you definitely need that front end to move freely.
accarter
Sep 21, 2015 11:56 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
2k232
Sep 16, 2015 10:28 AM
Sep 8, 2015 11:50 AM
iculookin
Sep 2, 2015 12:34 PM
