Headed to the track tonight
As far as my suggestions go. Just do everything exactly the same every run. Sometimes I would pop the clutch at 1500 rpms off the line. Shift at 4000 rpm every time. Bracket racing is not about performance, its about consistency. Get the car as hot as you can. It's a game, not a race.
PS I absolutely LOVE the wheels you have on your car.
Car looks really good, Crash. +1 on those wheels. Where did you find that tape? Or is it just painters tape? I usually just wipe mine off by hand after each pass, but it still leaves a slight residue sometimes doing it that way.
Your runs look good. You really only spun on one of the passes, but I did notice it sounds like you are leaving from a pretty low RPM on the others. Looks like the car is hooking pretty good on those passes, but its falling on its face as soon you get out with it. If you can bring your RPM up a little more and slip the clutch to compensate, it should hold the car at a higher RPM and keep the RPM and nose up better. Its harder to do on lowered cars imo since the rear doesn't squat as much, but it still helps. At any rate, car looks, sounds, and runs good, man!
Thanks stone, I tried from a range of 2k to almost 4500k on some runs and worked on my clutch slipping. I put my times on an excel sheet and saw that my car is just falling flat after the 1/8. :/ and ya. That's just painter tape, made it hella easy to clean.
Well damn, I have lots of painters tape! I'll use it next time. I hate how the track rubber sticks to the exhaust though, stuff cooks on there and stays!
Wow after seeing your on drag radials I take back the 2.0 is pretty good statement. Don't know what it is with the new edge guys struggling with their sixtys. I don't even know what kind of advice to give you and explosive. Seams like you guys are trying everything. If slipping the clutch isn't working just clutch drop at 4500 and hope something doesn't break.???
