Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
60ft
Old Oct 29, 2005 | 01:19 PM
jkm1987's Avatar
jkm1987
Default 60ft
my best 60ft w/my mods is a 2.0 i have ziex 512's 275/40/17's im launching at about 2700rpm is that my problem should i launch higher? LCA's and subframes are next on the list should these help out?
Old Oct 29, 2005 | 01:26 PM
angcobra's Avatar
angcobra
Default RE: 60ft
with street tires and sport springs it is hard to get below 2.0 due to wheel spin. Some of my best times on street tires was a launch of 2000 rpm or less.
Old Oct 29, 2005 | 01:54 PM
TommyV8's Avatar
TommyV8
Default RE: 60ft
Just get drag radials; the best I've done on regular street tires is 2.0. If I try to gun it they just sit there and spin, sometimes even mid-track.
Old Oct 29, 2005 | 01:57 PM
jkm1987's Avatar
jkm1987
Default RE: 60ft
the wheel spin was really bad when i had 245's on it now ive got 275's and its helped out alot i really dont spin that much i dont push it too hard right at first though so i dont spin real bad just kind of easy the clutch out and open it up at about 4k shift at 5.6.k but i do get a little loose going into 2nd for sure
Old Oct 29, 2005 | 03:58 PM
*Blk_96_Stang_GT*'s Avatar
*Blk_96_Stang_GT*
Default RE: 60ft
My best 60 was 2.2 and i got street tires and an auto, i was preloading at 2,000. Should i preload a lil lower or not at all to get my 60 down? or just buy tires
Old Oct 29, 2005 | 04:14 PM
Demon 340's Avatar
Demon 340
Administrator
Default RE: 60ft
buy tires if you can, but that is always a given. what does your car run in the 1/4?
Old Oct 29, 2005 | 07:29 PM
*Blk_96_Stang_GT*
Default RE: 60ft
A very very slow 15.3
Old Oct 30, 2005 | 01:34 AM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default RE: 60ft
i must have completely sucked
but for you, i would say invest in tires, cause your not haveing trouble keeping traction to pull a 2.0 on stock tires,
i would say that with some dr's you should improve it a bit better
99GT 5sp 4.10's and MT ET Street Radials = a crappy 2.050 for a 14.086@99.37
you guys think i should have pulled a 1.8** or is that wishing for too much?
Old Oct 30, 2005 | 04:10 AM
CJFANNI's Avatar
CJFANNI
Default RE: 60ft
You should hit a 1.6, 1.7, with those tires and gears, put about 14 pds in the tires and heat them up real good and there u go
ORIGINAL: 72MachOne99GT
Old Oct 30, 2005 | 04:50 AM
ZW99GT's Avatar
ZW99GT
Default RE: 60ft
U can cut much better than 1.8. I ran a 1.87 on Falken street tires. Do a second gear burnout to get those slicks sticky and launch off the rev limiter. I did just this in my 99gt with 3.73's and everything went great. The halfshafts CANT like this, but i had no problems. Good luck!
