Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
60ft times
Old Nov 3, 2005 | 05:27 PM
Bob99GTConv's Avatar
Bob99GTConv
I ♥ Acer
Default 60ft times
My MT drag radials, 275/40/17 should be in tomorrow and Im going to the track Sunday. My best 60ft with the Nitto's was a 2.02 with some spin launching at 2700RPM. Anyone think I can pull a 1.8ish? Oh and everyone keeps telling me I cant run 275 on my 8 inch rims? But ive been doing it. [&:]
Old Nov 3, 2005 | 05:42 PM
ZW99GT's Avatar
ZW99GT
Default RE: 60ft times
1.8 should be no problem. Just heat um up real nice and drop if from about 4-5k. Hell, if u arent scared, drop it from the limiter. All u will break is some rear end stuff that needs to be replaced anyway. LOL. Have fun with it man!
Old Nov 3, 2005 | 06:29 PM
Bob99GTConv
I ♥ Acer
I would if my limiter wasnt raised to 6800RPM[sm=gears.gif] hahah. Im gonna try 5000 first
Old Nov 3, 2005 | 11:33 PM
ZW99GT's Avatar
ZW99GT
Why do u have the limiter so high? Do you have Cams? 5k sounds like a good place to start off with. GOOD LUCK
Old Nov 4, 2005 | 02:23 PM
Bob99GTConv
I ♥ Acer
I had it raised beacsue I wasnt hitting the rev limiter in 1st at the track(6200) It pulls good until 6300-6400 in first.
Old Nov 4, 2005 | 03:06 PM
66chevyIISS's Avatar
66chevyIISS
ORIGINAL: Bob99GTConv
I always find it funny when I read comments like these. Just because it will go to 6400 rpms doens't mean you will be faster. Your car might run faster shifting at 5800. What heads do you have? have they been ported? what cam? If its a stock cam and heads you're wasting time shifting at 6400. Where is your peak HP rpm?
my car is still pulling at 7,000 rpms but I run slower then if I shift at 5900.
Old Nov 4, 2005 | 06:59 PM
Demon 340's Avatar
Demon 340
Administrator
the same goes for my car. i shift around 6200, but it will pull up to 7000ish..hell, in the burnout box, i was hitting 7500..
then the top end came apart...
Old Nov 4, 2005 | 07:26 PM
Derf00's Avatar
Derf00
Gentleman's Relish
You need to have a dyno chart and set your limiter just past where you peak out otherwise you're just wasting your motor.
As for the tire size vs rim size
http://www.yokohamatire.com/utrimwidth.asp
Old Nov 4, 2005 | 07:35 PM
Demon 340's Avatar
Demon 340
Administrator
or if you dont have a dyno chart available, just try playing with your shift time a bit, see where your best times come.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
