Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
launching
Old Feb 23, 2006 | 11:45 PM
torched04's Avatar
torched04
Default launching
What do you guys is a good launch rpm for my stang i have been testing and i think 3 grand is just right what do you guys think?
04 mustang gt
torch red
premium package
stock
Old Feb 23, 2006 | 11:49 PM
BlackSVTsnake302's Avatar
BlackSVTsnake302
Default RE: launching
Try 3 and see what happens otherwise just keep experimenting
Old Feb 24, 2006 | 12:44 AM
OneGearhead's Avatar
OneGearhead
launchin in a rwd v8 is like an experiment............you need the RIGHT variables, the right amount of those variables, etc, etc. try it at 3k......spin too much, take it down to 2k...........bogs down, take it to 2.5k, etc, etc. i can launch right around 1300rpm's and it hooks up, yet doesnt bog, so, voila.
Old Feb 24, 2006 | 01:43 AM
03sonicgt's Avatar
03sonicgt
I launch around 2500rpm's and feather the gas till around 3500 then I floor it. Last time I had virtually no wheel spin with winter tires hahah.
Old Feb 24, 2006 | 01:47 AM
RiCe_KiLlEr's Avatar
RiCe_KiLlEr
i found it much easy to launch at like 1500rpm's, anything else id just spin like a bitch. i need new tires . my best e/t is 14.065, i pulled a 2.1 60ft and that was launching at 1500rpm. just experiment and tell us your results
Old Feb 24, 2006 | 08:04 PM
dan's Avatar
dan
with one passenger, any higher than 1900 and my tires are smoke (stock tires).
Old Mar 1, 2006 | 01:33 AM
torched04's Avatar
torched04
thanks i will
Old Mar 1, 2006 | 01:53 AM
redmustang83596's Avatar
redmustang83596
also dont just go up to the line and rev up and dump the clutch, thatll spin the **** outta the tires, its an art of sorta slipping the clutch out just a little
Old Mar 1, 2006 | 02:38 AM
racer02GTstang's Avatar
racer02GTstang
normally what i do is get the car to a roll be just not dropping the clutch but letting off it slipping it real fast to just alittle past the gripping point... so so it may chirp tires sometimes... then i ease on it through 1st gear and part way through 2nd and then i gun it and im gone.... (this is with street tires on my setup)... that is with some spin at the end of 2nd and i shift it alittle softer into 3rd so i dont spin badly. same with going into 4th.... when i use to be n/a.. i would launch at about 2k rpms... i would slip the clutch real quick to get to a rolling start then i would floor it once i was rolling at say like 4 mph and that would be the best way to get it for me..... the best i ran was a 2.2 60' on stock tires while having gears and everything... i spun alot though at that track only coming up with a 9.4 @78.. i havent ran it at the better track around here yet....
ctgreddy
Oct 14, 2015 09:05 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
vintageaion
Sep 8, 2015 10:45 AM
