Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Trap Speeds
Old Feb 27, 2006 | 01:17 AM
redmustang83596's Avatar
redmustang83596
Default Trap Speeds
So last time i went to the track and i had a number of problems with the car: upper intake not bolted to lower intake, bald *** tires, stock *** gear, worn out 3rd gear synchro, half functioning spark box, incorrectly gapped plugs, and there might be a few more but thats all i can think of right now... but the point was that i only managed to run a 13.0 but i trapped 118, why does this happen? normally when i see a 118 MPH trap speed its on a low 12-high 11.. so why did i trap 118 on a 13.0?? i assume that i would trap higher with all of problems fixed too...
Old Feb 27, 2006 | 03:19 AM
Bullitthead's Avatar
Bullitthead
Default RE: Trap Speeds
The most likely culprit is a bad launch. You're probably churning away several tenths at the starting line. What were your 60' times?
As you mentioned, it seems that you are making enough power to run deep into the twelves...[8D]
Old Feb 27, 2006 | 05:19 PM
redmustang83596
if i rolled out off the line i would pull a 2.0 60' roasting them through 3rd and if i launched hard id pull a 2.2 60' just flat out burning the **** out of my tires all through 3rd
Old Feb 27, 2006 | 07:48 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
No offence but it sounds like you need more seat time, better tires and maybe some suspension work. BTW 118mph is good for a low 11 if you get your 60 foot down into the 1.6's
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
TCStangerv6
Oct 11, 2015 05:57 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
