Suspension Ask all of your general suspension questions here!
suspension setup help
Old Sep 12, 2011 | 02:37 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Sway bars are a tuning device and as such, should be the last item on a suspension upgrade list. They are indeed for the addressing of understeer/oversteer issues, so do EVERYTHING else first and see where your needs are.
If you DON'T plan to do any further changes to suspension, a rear sway bar is the direction you should look, if you want to dial-out some of that understeer. Keeping in mind, that understeer is considered by many to be safer than oversteer and I would agree (so long as it is not extreme).
Typically, the SN95 can use a bit of additional rear sway bar to achieve a better over all balance, but this is really a "per user" defined item. There is nothing wrong with a bit of understeer, but am a bit more reluctant to say the same about oversteer.
Jazzer
Old Sep 13, 2011 | 08:30 AM
d.girardi's Avatar
d.girardi
Im okay with the amount of understeer I have right now so after my next upgrades we will see where I stand with it
Old Sep 13, 2011 | 10:14 AM
1slow67's Avatar
1slow67
ROTM Moderator
Do you have a strut brace to keep the front from flexing?
Old Sep 13, 2011 | 12:20 PM
Jazzer The Cat
Retired Moderator
I would not bother with a STB on a post-Fox Body Stang
They really don't offer any help to a DD ride on the street, I'm afraid. It would be hard to justify one on the open-track/AX course as well, but certainly won't hurt anything.
Jazzer
Old Sep 13, 2011 | 10:32 PM
d.girardi's Avatar
d.girardi
That's a negative. But I also have heard they do not do much for my body style.
Old Sep 14, 2011 | 07:49 AM
Jazzer The Cat
Retired Moderator
Where did you hear that?
Old Sep 14, 2011 | 11:32 AM
Hotchkis's Avatar
Hotchkis
Former Sponsor
Originally Posted by d.girardi
Im already running 245/45/18 all the way around on a summer tread. I didn't want to mess with sway bars yet as I don't really 100% understand which ones would be best for me. As for pushing it to its limits, I doubt it. It does understeer a little and from what I understand that's what you want, correct?
d.girardi – Every driver has their own preference as to the setup of their vehicle. The goal is typically to get the front and rear bias equal. Having a little more oversteer is usually preferred to having extra understeer.
Properly setup springs and sway bars (and good tires) will get you to a properly balanced car.
Old Sep 14, 2011 | 08:41 PM
d.girardi's Avatar
d.girardi
more than likely something i've read of yours, im gonna guess.
Old Sep 14, 2011 | 08:48 PM
Jazzer The Cat
Retired Moderator
I was funnin', as I said it directly above the Hotchkis post
Jazzer
Matt's 95 Stang
Oct 5, 2015 07:16 AM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
